damen_red 52 Posted November 16, 2020 Report Share Posted November 16, 2020 I have a '67 520 with dual headlamps, I was wondering if anyone knew where the original chassis ground strap was located? Thanks! 1 Quote Link to post
datzenmike 39,256 Posted November 16, 2020 Report Share Posted November 16, 2020 Usually the stock ones are molded into the negative cable at the post but these clamps don't last forever and owners Might replace them. The negative cable itself is always grounded to the block so easy enough to run a 12 gauge wire with lugs on the ends from the block to the fire wall. Maybe a valve cover bolt to firewall. Summit... https://www.summitracing.com/parts/aaf-all76330?seid=srese1&gclid=Cj0KCQiA48j9BRC-ARIsAMQu3WTiIh1grim19vO-MHxK2fV0Oq0idQyX1gurLlpWQDXuSXzp1ZxgMjMaAqhYEALw_wcB 2 Quote Link to post
