CALsDookieDatsun
Issue fitting weber carb on a stock l20b engine
1979 Datsun 620 stock L20B engine
I'm learning as I go. Had my engine rebuilt and will be putting a weber 32/36 and the studs don't line up on the intake. The 2 adapters that came with it also don't fit over the studs. The studs on the intake too close together. Is there any adapter kits anyone can link or possibly another intake that will fit my truck?
Share this post
Link to post
 Where did you get your Weber? If from a yard sale the adapters could be for a Toyota or something.
A reputable dealer like Pierce Manifolds sells replacement Weber conversions for L series engines with adapters that fit. Maybe you can see them about a correct one.
There are also a lot of Asian knock off webers out there on the market. They are crap quality and definitely NOT Weber.
Share this post
Link to post
I bought it from redline. It was recommended to me on this site. I will check out Pierce Manifolds and see what I can find. Thanks for a direction!
Share this post
Link to post
Pierce Manifolds used real Redlne Webers.
I find it odd they sent two adapters. Contact where you got and tell them maybe a mistake was made.
Share this post
Link to post
Some adapter are two piece, one screws into the manifold with flush allen screws and then the top on bolts to that and then the carb
Weber and Header for my 77′ Datsun – Gordon French
Share this post
Link to post
That's what I have except it doesn't line up and it looks a bit different than the one in that image, but it is the 2 piece. Maybe they sent the wrong adapters. I'll see if I can find those.
Share this post
Link to post
I may be misunderstanding but,,,, You say “ won’t fit over studs”. ( I assume original studs)
   You have to remove the original studs that are in manifold
Edited by bananahamuck
Share this post
Link to post
^^^^ I should say,,, Most times you have to remove at least one set .
Share this post
Link to post
