Alg86 Posted November 15, 2020 Report Share Posted November 15, 2020 This is my first Datsun. It’s a 71 510. The guy I picked it up from didn’t know much about about. Trying to figure what the 5 lug and brake conversion came from. Need to figure out if this is the same or different then the factory offset. I put a s2000 wheel that was in the shop. It hits the front coilover and sticks out an inch or so past the fender. Can anyone help identify the parts? https://www.dropbox.com/s/r859p9q7ldl9lt8/Photo Nov 15%2C 12 10 31 PM.jpg?dl=0 https://www.dropbox.com/s/a9ey3yhimdv7ptc/Photo Nov 15%2C 12 12 54 PM.jpg?dl=0 Quote Link to comment
datzenmike Posted November 15, 2020 Report Share Posted November 15, 2020 Always check you links after posting to be sure they work. What car or truck do you have? and put it in your profile so it can be referred to without asking. If it hits the coil over AND sticks out past the fender no amount of off set change will fix this. The Z31 300zx turbo '-84-'89 came with 5 lug. All later Z32 300zx were 5 bolt. The Feb '94 and up S14 240sx had 5 lug. Quote Link to comment
Alg86 Posted November 15, 2020 Author Report Share Posted November 15, 2020 2 hours ago, Alg86 said: This is my first Datsun. It’s a 71 510. The guy I picked it up from didn’t know much about about. Trying to figure what the 5 lug and brake conversion came from. Need to figure out if this is the same or different then the factory offset. I put a s2000 wheel that was in the shop. It hits the front coilover and sticks out an inch or so past the fender. Can anyone help identify the parts? https://www.dropbox.com/s/r859p9q7ldl9lt8/Photo Nov 15%2C 12 10 31 PM.jpg?dl=0 https://www.dropbox.com/s/a9ey3yhimdv7ptc/Photo Nov 15%2C 12 12 54 PM.jpg?dl=0 71 Datsun 510 Quote Link to comment
Bleach Posted November 15, 2020 Report Share Posted November 15, 2020 The brake calipers both look like front and rear from a Z32. I think there may also be similar calipers that game on the Nissan GTR but that would be far more rare. The rear hubs are re-drilled so it is probably just 5x4.5 The front looks OEM. I'm not sure, but I think the late Z31 turbo looks like that (strut assembly) and can also bolt up the Z32 caliper. Late Z31 would be 1987-89 300ZX If that is the case, then I suppose the rotor set that fits would be 1988 300ZX turbo. Quote Link to comment
datzenmike Posted November 15, 2020 Report Share Posted November 15, 2020 They are working now. Z32 '90- '96 300zx brakes. I guess rims that would fit these year 300zx would work. Quote Link to comment
