Dirtyowlnumber4 Posted November 8, 2020 Report Share Posted November 8, 2020 It seems pretty happy at 30 degrees and it runs well but is it normal to be that advanced? its an a14 with electronic ignition and a weber Quote Link to comment
datzenmike Posted November 8, 2020 Report Share Posted November 8, 2020 https://getyarn.io/yarn-clip/f7889fbc-b69e-4dee-9aff-231b468beb7d No that is not right or you're mistaken. Have you had the distributor out? It may be in wrong and out a tooth requiring the distributor to be turned that far to compensate. I think there are 10 teeth so 36 degrees per tooth??? Quote Link to comment
banzai510(hainz) Posted November 10, 2020 Report Share Posted November 10, 2020 maybe your reading the crank marks from the wrong side???????????? 30 is a bit too far off. put the motor on TDC and look where your rotor points in relation to number 1 plug wire spot on distributor cap. Quote Link to comment
Tom1200 Posted December 23, 2020 Report Share Posted December 23, 2020 late to the party 30 degrees at what RPM? I run 38 degrees (per the competition manual) at 4000 rpm. 1 Quote Link to comment
