afracer Posted November 4, 2020 Report Share Posted November 4, 2020 For 79-83 B310s, does the wagon and 4 door sedan use the same door weatherstripping? I know the 4 door wagon and 2 door coupe use the same windshields and weatherstripping there, but unsure on other pieces. It seems the front door between the coupe and wagon are different lengths with the 2 door coupe having longer doors, would suspect all 2 doors share door weatherstrip and 4 doors between all models share door weatherstripping but want to make sure before ordering. Quote Link to comment
Cleopatra Jones Posted December 6, 2020 Report Share Posted December 6, 2020 Sorry I'm just seeing this. You could've had an answer sooner. 2 door and hatchback do not use the same weatherstripping. Part numbers are different and the hatchback's door is actually shorter than the 2 door. Can't even use the glass because it's shorter. Door panels are the same though. The wagon and 4 door sedan have different part numbers for the weatherstrip on the front doors as well as the back. I did buy some aftermarket weatherstripping on ebay. I think it was for the hatchback/coupe but it fit my 2 door although one side was long. I think that was the passenger side and I ended up getting the very last passenger side from Nissan a few years back. The aftermarket rubber is shit (it wears faster) but it's better than nothing. I honestly couldn't say how well it would work if you found sedan vs wagon. I'll PM you with this as well in case you don't see it here. 1 Quote Link to comment
