Lee w Stevens jr Posted November 1, 2020 Report Share Posted November 1, 2020 I have a 1967 datsun pickup I need some help with some of the wiring harnesses and if anyone know where I can find some parts like a carburetor and radiator maybe a grill 1 Quote Link to comment
datzenmike Posted November 2, 2020 Report Share Posted November 2, 2020 What is the electrical doing... or not doing? Parts wanted...https://ratsun.net/classifieds/category/9-datsun-parts/ 1 Quote Link to comment
Lee w Stevens jr Posted November 2, 2020 Author Report Share Posted November 2, 2020 I need to know which wires go to the alternator which wires go to the coil cousin negative still on but the positive wire broke off the coil and there's a couple wires is lying around I got the ignition rekey the doors rekeyed it's a 3-wire ignition so can't be much to it I'm just not too sure about it 1 Quote Link to comment
zed1 Posted November 3, 2020 Report Share Posted November 3, 2020 Welcome. Photos of your 520 will help us determine exactly what you have. (Some 1966 520’s were titled as 1967.) keith 1 Quote Link to comment
datzenmike Posted November 3, 2020 Report Share Posted November 3, 2020 On 11/1/2020 at 9:56 PM, Lee w Stevens jr said: I need to know which wires go to the alternator which wires go to the coil cousin negative still on but the positive wire broke off the coil and there's a couple wires is lying around I got the ignition rekey the doors rekeyed it's a 3-wire ignition so can't be much to it I'm just not too sure about it Get a $3 test lamp. Clip the alligator clip to ground and anything you touch with the probe will light the bulb if 12v is present. You should have one of these anyway, they are invaluable for tracing power or grounds. COIL One of those wires will have power with the ignition on. This will connect to a ballast resistor, a small rectangular ceramic thing with a terminal on each end. The wire on the other end will go to the positive terminal on the coil. Another wire will have power only when the ignition is in the start position. This wire goes directly to the positive terminal of the coil also. ALTERNATOR Black is ground and bolts to the alternator case White/Red stripe is the power output and bolts to an insulated terminal on the case. The other two wires have a plastic plug and can't be plugged in wrong. 2 Quote Link to comment
Charlie69 Posted November 5, 2020 Report Share Posted November 5, 2020 67/68 wiring diagram. 1 Quote Link to comment
Charlie69 Posted February 14, 2021 Report Share Posted February 14, 2021 65/66 wiring right hand drive same as left hand drive wiring just different sides of thetrruck. Quote Link to comment
