Datsunny72 Posted October 30, 2020 Report Share Posted October 30, 2020 Looking to purchase Datsun 63a (dogleg) Transmission for the A series motor willing to pay shipping on my end contact me at : 8609928321 email: vickturorteez@gmail.com Quote Link to comment
datzenmike Posted October 30, 2020 Report Share Posted October 30, 2020 Try here... https://ratsun.net/classifieds/category/9-datsun-parts/ The 210 (B-310) had 60 series speeds. The '79 was a dogleg shift pattern and the '80 and on were regular H pattern. Most of these were scrounged by MG owners. Quote Link to comment
Dguy210 Posted October 30, 2020 Report Share Posted October 30, 2020 (edited) 1 hour ago, datzenmike said: Try here... https://ratsun.net/classifieds/category/9-datsun-parts/ The 210 (B-310) had 60 series speeds. The '79 was a dogleg shift pattern and the '80 and on were regular H pattern. Most of these were scrounged by MG owners. '78 B210 hatchbacks also had the 63A dogleg. This seems to be the most common source too. I've heard, but not been able to confirm, you could actually get it as an option in earlier years. Note for OP: the 63A transmission uses a different and specific clutch plate and a different driveline (same as B210 auto or 510 sedan). It has the larger spline output as it is basically a converted L series transmission. If this is going into a vehicle with a H145 diff such as a 1200 you will either need to find a '74 B210 auto driveshaft (unsure if 1200 auto driveshaft uses same larger spline- I believe it does but not positive) or swap the center of the diff (or whole diff) to a H150 and use a '75 or later B210 auto driveshaft or 510 sedan driveshaft (better and easier to find). If you already have a 63A transmission and are looking for a replacement you could with some difficulty mind you, use an L series 63A transmission and swap bellhousings and have the end of the pilot rod reduced in size for the smaller pilot bearing (might be able to swap bits around too depending on what you have). Edited October 30, 2020 by Dguy210 Quote Link to comment
datzenmike Posted October 30, 2020 Report Share Posted October 30, 2020 April '76 was the earliest availability of the 63A. Only the DX coupe (2 dr hatchback) got them. 1 Quote Link to comment
bilzbobaggins Posted October 30, 2020 Report Share Posted October 30, 2020 Was it not standard on the gx in 78? Quote Link to comment
datzenmike Posted October 30, 2020 Report Share Posted October 30, 2020 That's what I heard but the GX is a trim level isn't it. I only have sedan 2 or 4 door ad coupe, Can, Calif. or Federal, 4, 5 or automatic to choose from. DX is delux??? Maybe the GX is the delux??? Quote Link to comment
bilzbobaggins Posted October 30, 2020 Report Share Posted October 30, 2020 I have no clue. Its been 23ish years since I saw mine. I miss that car. I can still smell it and remember it. I still cant find a pic of her anywhere. Quote Link to comment
Dguy210 Posted October 31, 2020 Report Share Posted October 31, 2020 8 hours ago, datzenmike said: April '76 was the earliest availability of the 63A. Only the DX coupe (2 dr hatchback) got them. That's what I vaguely remembered but glad to get confirmation and yeah I actually have the resource material to look it up but lazy. 7 hours ago, datzenmike said: That's what I heard but the GX is a trim level isn't it. I only have sedan 2 or 4 door ad coupe, Can, Calif. or Federal, 4, 5 or automatic to choose from. DX is delux??? Maybe the GX is the delux??? Yep, GX did not mean 5spd necessarily. However, it did seem many of the GX trims did come with the 5 spd and I believe only the hatchbacks got the GX trim. Quote Link to comment
datzenmike Posted October 31, 2020 Report Share Posted October 31, 2020 I have owned a new '76 2 dr.sedan and later a hatchback but I forget the year I think a '76.... and it was 4 speed. Quote Link to comment
