620BEAMS Posted October 21, 2020 Report Share Posted October 21, 2020 Hi All, New member here, i'm fitting fender flares to my 620 and am just wondering, are the rear arches single skin like the fronts or are the double and therefore will require 'tubbing'? Thanks, Quote Link to comment
datzenmike Posted October 21, 2020 Report Share Posted October 21, 2020 About half way up and running horizontally from front to back through the wheel opening there is a spot welded seam where the top of the bed, the two bottoms of the bed and the bed floor meet. Above the bed is the wheel well spot welded to the top part of the bed and to the bed floor. The 620 does not have an inner bed liner and the outer skin subject to dings from carrying cargo. I think the earliest truck liner was the '85 720. So, no I don't think tubbing is needed. Quote Link to comment
620BEAMS Posted October 21, 2020 Author Report Share Posted October 21, 2020 40 minutes ago, datzenmike said: About half way up and running horizontally from front to back through the wheel opening there is a spot welded seam where the top of the bed, the two bottoms of the bed and the bed floor meet. Above the bed is the wheel well spot welded to the top part of the bed and to the bed floor. The 620 does not have an inner bed liner and the outer skin subject to dings from carrying cargo. I think the earliest truck liner was the '85 720. So, no I don't think tubbing is needed. Fantastic, thanks very much Mike! I thought that was the case but just wanted to check. Cheers Quote Link to comment
