Ben M Posted October 19, 2020 Report Share Posted October 19, 2020 On the transmission on the 521, there are 3 switches near the back. During the disassemble process the wires to the switches got cut and unfortunately I don’t think they are salvageable. So my question(s) is this: What are the purpose of the switches? Do I absolutely need all 3 of them? And where would a good place be to find new ones? If it matters, I’m running stock everything. Stock engine, transmission, carb etc. Thank you! Quote Link to comment
wayno Posted October 19, 2020 Report Share Posted October 19, 2020 DanielC will likely be able to tell you what each switch does and where it is at, one is for the backup lights, another one is likely an emissions switch for the dual points distributor, and maybe one is for when it is in a certain gear, but I am guessing on the last two suggestions on what they are, Dmike might know also. I don't believe I used any of them except the backup lights switch. 1 1 Quote Link to comment
gene knight Posted October 19, 2020 Report Share Posted October 19, 2020 the 1 that is by itself near top and closer to shifter rod is neutral gear switch and the 2 that are close together and closer to the bottom are for transmission switch 3rd gear and other is reverse gear switch 1 1 Quote Link to comment
Greaser2 Posted October 19, 2020 Report Share Posted October 19, 2020 If you don’t have original distributor then you can loose two of them. Just need the reverse. 2 1 Quote Link to comment
Ben M Posted October 19, 2020 Author Report Share Posted October 19, 2020 45 minutes ago, Greaser2 said: If you don’t have original distributor then you can loose two of them. Just need the reverse. I only have the original distributor at the moment, do I 100% need to use the other two or could I get away with just the reverse gear? 1 Quote Link to comment
datzenmike Posted October 19, 2020 Report Share Posted October 19, 2020 For reducing pollution these switches allow the distributor to select an advanced or retarded set of points depending on the gear you are in, the throttle position, outside temperatures. Generally, running retarded will cut performance/mileage so I would just leave everything as is and remove or unplug the relay that enables the retarded set of points and drive away. 1 1 Quote Link to comment
mainer311 Posted October 19, 2020 Report Share Posted October 19, 2020 1 hour ago, Ben M said: I only have the original distributor at the moment, do I 100% need to use the other two or could I get away with just the reverse gear? You can just use the one for reverse, and leave or plug the other two. Truck will still run, it just won't utilize the "retarded" set of points. There's a bit of irony there. 1 1 Quote Link to comment
Greaser2 Posted October 19, 2020 Report Share Posted October 19, 2020 Plus a switch on the clutch pedal, WOT switch on carb and a relay all have to work it’s amazing these old Dis work. 1 1 Quote Link to comment
mainer311 Posted October 19, 2020 Report Share Posted October 19, 2020 Mine didn’t. I’d be shocked if any of them did. 1 1 Quote Link to comment
Ben M Posted October 20, 2020 Author Report Share Posted October 20, 2020 Thank you all for the responses! I really appreciate the help. I should be able to figure it out from here. 🙂 1 Quote Link to comment
