Stinky Posted October 14, 2020 Report Share Posted October 14, 2020 At what level, in #PSI should my oil pressure light come on in my 86 720? 1 Quote Link to comment
datzenmike Posted October 14, 2020 Report Share Posted October 14, 2020 I think around 8psi. You can run an engine on 8 PSI but I wouldn't work it too hard. If you really want to know the exact pressure install a real gauge. On a hot engine, even a high mileage one with worn and wide clearances on the bearings 50-60 PSI is normal when revved up, certainly out on the highway. Idle is much different as less oil is pumped and it can easily 'bleed' past bearing faster than it can be pumped. My very worn L20B made 17 PSI at hot idle with a stock oil pump and 29 PSI with a KA oil pump. My present L20B makes 35 while turning with the starter, with a KA oil pump. 1 Quote Link to comment
Stinky Posted October 15, 2020 Author Report Share Posted October 15, 2020 In the past week, 2x the light has flickered will moving at an idle in 2nd, when leaving for work w.o a warmup 1 Quote Link to comment
datzenmike Posted October 15, 2020 Report Share Posted October 15, 2020 Replace the sender, I think >$20. 1 Quote Link to comment
