activemetal Posted October 13, 2020 Report Share Posted October 13, 2020 Hi, does anyone have any tips for the rear main cap side seals (L16 engine)? i put the silicone in the side corners, set the main-cap in place 1/8 above bottom then inserted (pushed) the rubber seal down to the bottom (lips to the block), snugged up the cap and then tried to put in the metal shims (nail?) in between the cap and the seal (as the tom monroe book said with bevel toward the cap) but only got 1/2 way before the metal shim bent because it was so hard to push. So purchased a new seal kit and wanted to hear any tips before i re-tried to install. Thanks in advance for the help. Cheers Quote Link to comment
datzenmike Posted October 13, 2020 Report Share Posted October 13, 2020 I would put the bolts in but wouldn't tighten them till the seals are in place. The Nissan manuals say to apply sealant to the side seals too before installing them. Maybe this 'greases' them and allows the steel shim to slide in easier? I've put them in before and used a hammer to gently tap them in. Quote Link to comment
activemetal Posted October 13, 2020 Author Report Share Posted October 13, 2020 datzenmike... thank you FYI..... the guys on the facebook page Church or L strongly recommended going with the OEM seals as they are much easier to install since the metal is embedded in the rubber ...they gave a part # Nissan Part No.:12289-W0400.... so i will do that. Thanks for all the help. Cheers Quote Link to comment
Stoffregen Motorsports Posted October 13, 2020 Report Share Posted October 13, 2020 I use Gasgacinch on the side seals. It helps them slide in, but also aids in adhesion. It will also get into the corners and seal up potential leaky points. Note that they sometimes stick up a tiny bit after installation and this is normal. Quote Link to comment
