Ethan davis Posted October 11, 2020 Report Share Posted October 11, 2020 I own a 620 Datsun pickup and am trying to grease All the joints suspension and everything after a oil change. I easily found the grease joint for the lower ball joint, but can't figure out or can't find the grease joint for the upper part of the suspension for the ball joint. Anyone got any suggestions? Quote Link to comment
datzenmike Posted October 11, 2020 Report Share Posted October 11, 2020 This is a '78 or '79? Follow the upper control arm out towards the tire. It's triangular with the base towards the frame and the point at the tire with the ball joint connecting it to the hub below it. It's possible that the ball joint may not have a fitting for grease and it's either missing or there is a removable plug for grease. Then again it might have been replaced with a non serviceable joint. Quote Link to comment
