East LA Mike Posted October 3, 2020 Report Share Posted October 3, 2020 Any recommendations on a individual or shop in the area of Burbank Calif or SoCal that’s real familiar with replacing the headliner of a 240Z? Thanks! Quote Link to comment
yenpit Posted October 14, 2020 Report Share Posted October 14, 2020 It is actually very simple, unlike the 510 620 etc that has steel rod bows. The Z is a piece of 1/4 foam glued to the roof & vinyl glued to the foam. Depending on where you buy vinyl, you might be able to buy vinyl with foam already glued to it. Use aerosol trim adhesive & take time to place it. Cut bigger, spray glue everywhere you need it, put the center up first taking care not to wrinkle it, then trim the edges leaving enough to tuck up behind all four of the roof rails. If you also need to do the roof rails, I have never done those, might require a professional hand......?? Any good upholstery shop can handle the complete job! Quote Link to comment
