grannyknot Posted September 19, 2020 Report Share Posted September 19, 2020 When I removed the 4 bolts that hold the diff in the rear cross member I noticed there were I think 4 spacer bars or maybe washers that hold the diff in the center of the cross member, well I have put them somewhere so safe I can't find them. I haven't been able to find a good exploded diagram of the rear end so was wondering if anyone had a pic of these spacers that they could post up so I know what I'm looking for? Also, I noticed that there is a momentary switch that is actuated when the gas pedal is to the floor,(this is a 73/510) just wondering what this sensor is for or what it cuts power to? Thanks Quote Link to comment
datzenmike Posted September 19, 2020 Report Share Posted September 19, 2020 You must have an automatic car. That's the electric kick down switch. sthe auto to drop down a gear and make the engine make more noise even if it doesn't go much faster. Quote Link to comment
grannyknot Posted September 20, 2020 Author Report Share Posted September 20, 2020 That makes sense, the brake pedal was from an automatic and I had to cut it down so a manual brake rubber pad would fit over it. Quote Link to comment
datzenmike Posted September 20, 2020 Report Share Posted September 20, 2020 So this was swapped to a standard? The auto gas pedal has a different mount location than a standard. If you remove the two screws and look at the floor there is a third dimple allowing the choice of left or right positioning of the pedal. But if you have the original auto brake pedal still it doesn't need moving. I guess the standard brake is in the way or a tight fit so the gas is moved right to give it room. Something like that. Quote Link to comment
grannyknot Posted September 20, 2020 Author Report Share Posted September 20, 2020 Found them, staring me in the face. Quote Link to comment
