Sign in to follow this
afracer
Hitachi Choke Pull Off
I just finished rebuilding the stock Hitachi carb from my 90k mile '81 210 A15. After putting it all back together I applied vacuum to the choke pull off and it worked but quickly leaked vacuum. My other spare carb was even worse so I'd imagine this is a common wear item if its never been replaced. I bet there's a bunch of y'all with vacuum leaks there and don't even know it!  I got a new one on the way but wanted to give y'all a heads up to check yours out for vacuum leaks.  That carb ran 'ok' but not all that great.  Fair warning!
Share this post
Link to post
Usually the hose cracks. It's job is to pull the choke off if you floor it for needed power. How often does this happen?
Share this post
Link to post
