Negative Ghostrider Posted September 15, 2020 Report Share Posted September 15, 2020 So after community input I went the extra mile to get an OSK timing parts kit instead of some generic ebay kit. I'm putting it in and the OSK cam sprocket doesn't have the location notches in it. WTH? How am I supposed to find the timing marks? The teeth on the new sprocket don't line up with the old one when I stack them using holes 1 and 3 as reference, either. So I can't use the old one to find the mark and then set the chain to the same number on the new one. Quote Link to comment
datzenmike Posted September 15, 2020 Report Share Posted September 15, 2020 Put the old cam sprocket back in. It's not worn out yet. That's why there are extra adjustment holes. If you can get this when at TDC... ... that's all you need. Just like setting ignition timing, doesn't matter where the rotor or spindle is pointing, as long as you can set it at 120. . 1 Quote Link to comment
Negative Ghostrider Posted September 15, 2020 Author Report Share Posted September 15, 2020 17 minutes ago, datzenmike said: Put the old cam sprocket back in. It's not worn out yet. That's why there are extra adjustment holes. If you can get this when at TDC... ... that's all you need. Just like setting ignition timing, doesn't matter where the rotor or spindle is pointing, as long as you can set it at 120. . OK, thanks. That was going to be the plan. The old sprocket seems to have plenty of life left in it. No signs of real wear. Just seems a shame to not put the new one in but what a strange design choice. Quote Link to comment
Negative Ghostrider Posted September 15, 2020 Author Report Share Posted September 15, 2020 I was able to put bolts through holes 1 and 3 and stack the sprockets back to back, instead of both facing up. The teeth lined up that way and I was able to mark the notches on the new cam with a sharpie. That should be work, right? Or should I just proceed with the new one? Quote Link to comment
datzenmike Posted September 15, 2020 Report Share Posted September 15, 2020 Good enough Quote Link to comment
banzai510(hainz) Posted September 16, 2020 Report Share Posted September 16, 2020 (edited) OSK has gone down in quality . what you did is what can do with timing chains that come with not brite links is use the old and back to back or side to side then mark it Edited September 16, 2020 by banzai510(hainz) Quote Link to comment
Stoffregen Motorsports Posted September 16, 2020 Report Share Posted September 16, 2020 X2 on re-using the old cam sprocket. Quote Link to comment
