Strut/Tension Rod Bushings
mrbigtanker
All, I have searched for awhile now and on this website, but with no luck. I need/want new strut/Tension rod bushings. Any help would be great.
MOOG part # is K9218 but seems to be either back ordered or obsolete. 510 is K9215 but MOOG is out of stock until who knows when.
Any other good sources parts or anyone with a stash they want to sell would be great.
  • Replies 11
43 minutes ago, Greaser2 said:
Did u try Jegs
Yes Summit, even called MOOG direct, there parent company had only 5 in the warehouse. I need 8. The problem was i wanted the K9218 which is the 521 part number, the K9215 is for 510's but fuck it, it should work.
20 hours ago, bilzbobaggins said:
I ordered two sway bar link kits and used the bushing out of that.  Then used the bolts to fix a gate to the backyard.
I did the same thing...well, except for the gate. They’re urethane and probably too stiff, but whatever.
Thats what I was trying to avoid, so I ordered the K9215 510 ones. That will be fine for my low horsepower truck.
  • Haha 1
7 hours ago, mikec4193 said:
That is the number but MOOG is out for awhile. Called them direct.
  • 1 year later...
