1982 720 pickup brake light wire issue
rnscustom
Ok so I’ve had a long term taillight issue . Finally found a taillight converter hooked up in the frame rail . I have eliminated that and everything works but not brake lights . I have a Yellow and red stripe wire left which seems to power when the brake light is pressed but the issue the turn signal doesn’t continue to flash when the brake is pressed . Hopefully I’m describing this right . The bed and taillights are hardbody if that makes a difference . One 2 element bulb . One side marker and  one backup for sockets . Thanks , Richard
  • Replies 0
