datzenmike Posted October 11, 2020 Report Share Posted October 11, 2020 ]2eDeYe on here sells a mount kit for 620 but probably works on the 521. He has a post on this. Inline high pressure fuel pump A return line Larger rad. Drive shaft shortened 3 Quote Link to comment
Zonargx Posted October 11, 2020 Author Report Share Posted October 11, 2020 (edited) @datzenmike any one know how they have done the fuel system for the return? Any help would be nice Edited October 11, 2020 by Zonargx 2 Quote Link to comment
Zonargx Posted October 11, 2020 Author Report Share Posted October 11, 2020 (edited) I think I’m just gonna go get that engine on Monday as I’m gonna be off if worst comes to worst and things need to be rebuilt I can gather parts and rebuilt it plus for $600 on engine, trans and ecu wiring harness combo is not bad Edited October 11, 2020 by Zonargx 2 Quote Link to comment
datzenmike Posted October 11, 2020 Report Share Posted October 11, 2020 The EFI on the KA will require a return line. You might be able to plumb it into the vapor separator container in front of the right rear wheel well. 3 Quote Link to comment
wayno Posted October 11, 2020 Report Share Posted October 11, 2020 Any 521 that has the vapor return has the extra fitting on the tank and you can even use that line going back there to use as the return line, just remove the hose going to the canister and pipe that line directly to the tank, the only issue I could see is if that vapor return line is not big enough, it worked fine for my SUs. 4 Quote Link to comment
Zonargx Posted October 11, 2020 Author Report Share Posted October 11, 2020 I would ask for pictures if possible I haven’t touched nor looked at that canister at all it I can do use it as a return it would probably make it easier to install a ka. You know what one thing I’m thinking about is the clutch stuff how will I make my clutch master work with the new slave of the 240 is it possible to just make a new hard like for it or is there any easier way. I have extra line from my front disk conversion and some fittings 2 Quote Link to comment
Zonargx Posted October 11, 2020 Author Report Share Posted October 11, 2020 If this ka has a flat top valve cover with the stripes in the middle of it it means it’s from a truck right? 2 Quote Link to comment
wayno Posted October 11, 2020 Report Share Posted October 11, 2020 (edited) 9 minutes ago, Zonargx said: I would ask for pictures if possible I haven’t touched nor looked at that canister at all it I can do use it as a return it would probably make it easier to install a ka. You know what one thing I’m thinking about is the clutch stuff how will I make my clutch master work with the new slave of the 240 is it possible to just make a new hard like for it or is there any easier way. I have extra line from my front disk conversion and some fittings The metal line does not go into the canister area, they use a rubber line to go in there as I recall, all you would need to do to use it as a return line is remove the rubber line from the hard line and put a new hose to the tank fitting, well you would need to remove the line from the canister to the tank also. I expect you could make something work using the old lines like cutting them and using a fitting to connect them together. What really counts is that you have that extra fitting on the tank, you can make your own line if you have to. Try using your clutch master to make the 240 slave work first. Edited October 11, 2020 by wayno 2 1 Quote Link to comment
Zonargx Posted October 11, 2020 Author Report Share Posted October 11, 2020 So I looked the engine up at apparently it’s a ka24e seems is that a good one instead of the ka 24de 3 Quote Link to comment
datzenmike Posted October 11, 2020 Report Share Posted October 11, 2020 Truck and car KAs, whether they are E or DE are the same but with different intakes. The DE is marginally better with 4 valves per cylinder vs. only 3 on the E. I like the E because I like big valve covers. 3 Quote Link to comment
]2eDeYe Posted October 11, 2020 Report Share Posted October 11, 2020 That's a single cam KA, can be car or truck. Car has a front sump, truck is a rear sump. 3 Quote Link to comment
Zonargx Posted October 12, 2020 Author Report Share Posted October 12, 2020 Good to know that. I want to know about an l20b swap also what will I need to fit one in because one of my options was that ka or the l20. If I go with the l20 what will I need? I’m gonna be looking for a 5 speed to pair it with so all the advice is helpful also will this also require the drive shaft to be shortened? 2 Quote Link to comment
wayno Posted October 12, 2020 Report Share Posted October 12, 2020 What is in the truck now,. an L16? 2 Quote Link to comment
Zonargx Posted October 12, 2020 Author Report Share Posted October 12, 2020 2 hours ago, wayno said: What is in the truck now,. an L16? Yes 2 Quote Link to comment
Zonargx Posted October 12, 2020 Author Report Share Posted October 12, 2020 7 hours ago, ]2eDeYe said: That's a single cam KA, can be car or truck. Car has a front sump, truck is a rear sump. Had to look up what sump meant. That practically my first time hearing that but I got it now 3 Quote Link to comment
datzenmike Posted October 12, 2020 Report Share Posted October 12, 2020 The L20B is identical to the L16 but is 2cm (3/4") taller. Use the L16 engine brackets and the oil pan and pick up tube. Use the L16 exhaust manifold. Try to get an L20B with a flywheel 2 Quote Link to comment
Zonargx Posted October 12, 2020 Author Report Share Posted October 12, 2020 22 minutes ago, datzenmike said: The L20B is identical to the L16 but is 2cm (3/4") taller. Use the L16 engine brackets and the oil pan and pick up tube. Use the L16 exhaust manifold. Try to get an L20B with a flywheel What 5 speed transmission can I pair it with? 2 Quote Link to comment
Zonargx Posted October 12, 2020 Author Report Share Posted October 12, 2020 I’m thinking of going the l20 way now and maybe getting some old school ssr wheels to make the truck have that nice Jdm vibe 2 Quote Link to comment
wayno Posted October 12, 2020 Report Share Posted October 12, 2020 The L20b would be the easiest route for you to go this time, it basically bolts right in except for the 5spd transmission mount which needs to be made or bought, I wrote an article on how to make/build a short shaft 5spd so you could use your existing drive line, but it's getting harder to find what you need anymore. I also made an LZ23 back in 2011 as I recall, it kinda tells you what I had to do and what I had to find(Z22 block without large cracks) to make it. I would build an LZ23 before doing an L20b build myself, but I am spoiled and don't want to take a large step backwards anymore, move forward or stay the same, putting an L20b in your truck is a large step forward compared to the L16, best upgrade I ever made to my Datsun 521 work truck, but I built another L20b with an RV cam and regretted it, that is when I built my LZ23, it was second greatest upgrade to my work truck I ever made, there is no substitute for displacement, the KA24 would likely also be a great upgrade, but I do not understand the newer computer controlled engines and all the sensors they have and I have not a clue how to wire them or fix them if they break down on the side of the road, that is why I like my LZ23, I have never had to be towed home in the last 9 years, I always was able to get within walking distance of my house before it would not go any farther, I walked home(3 miles), got an electric fuel pump and rode my bike back, installed it, thru the bike in the back and I drove home, I always carry an electric fuel pump with me now. 3 1 Quote Link to comment
datzenmike Posted October 12, 2020 Report Share Posted October 12, 2020 Myself a 71B from a late 620 truck an 810 or a Maxima, a 280z or a 280zx non turbo. Even the '80 720 had an L series 5 speed that will fit the L20B. These are all longer than your 521 4 speed so the drive shaft must be shortened. I'm sure wayno has mentioned the 720 short 71B that will fit your 521 drive shaft length but you have to find one and an L series front cast to swap onto it and I think shortening the drive shaft would be easier and cheaper. 3 Quote Link to comment
Zonargx Posted October 12, 2020 Author Report Share Posted October 12, 2020 I guess your right @datzenmike I guess I’d rather get the driveshaft shortened. All I would need help with would be the wiring I guess. Seems basic but I rather not mess something up. I’m not sure but is the LZ23 a inline six from the 240s/280s? 1 Quote Link to comment
Zonargx Posted October 12, 2020 Author Report Share Posted October 12, 2020 I want the most decent power I can get out of a l20 I can try to get a hold of one as soon as possible and slowly start building/getting the transmission until my L16 finally kicks the bucket or I get tired of it haha. 1 Quote Link to comment
wayno Posted October 12, 2020 Report Share Posted October 12, 2020 The LZ23 is nothing more than a Z22 block out of a 1981/82 Datsun 720 or a 200SX of the same years, I bored it out to except Z24 pistons and I put an L block head on it, an L20b front cover, and I used all the L16 stuff to mount it in the 521 truck, I would use the L16 exhaust manifold and intake also unless you are going to use Dual SUs, then just use the L16 exhaust manifold. The Z22 block is nothing more than an L20b block that has larger bore with a Z head on it. 3 Quote Link to comment
datzenmike Posted October 12, 2020 Report Share Posted October 12, 2020 Good power and torque from the added displacement but it means sourcing a lot of parts from two other engines and a probable rebuild. Here I would just get an L20B. You'll be pleasantly surprised with the increase in torque over the L16. I put a car L20B in my '71 521 back in the '70s. With a sudden switch like that you could feel it press you back in the seat in the higher gears. Thing is, in a few weeks you barely remember the L16 and want more push back in the seat. More, sadly, is never enough in the end. 4 Quote Link to comment
wayno Posted October 12, 2020 Report Share Posted October 12, 2020 The L20b was a good enough upgrade for me for over a decade, but I was dealing with other upgrades like disc brakes, power steering, and then power brakes and I was working full time on my own business, but eventually I came back to the power of the engine because the one I had was using oil, a lot of oil at the end, it got expensive burning 3 quarts of oil a tank of gas, so I built the LZ23, keep in mind back then that I tow a trailer and hauled a lot of weight daily, I was wearing out rearends, breaking transmissions, it was not uncommon for me to be rolling around with a rolling weight of over 7000lbs, so the LZ23 was a welcome upgrade, I have been fine with the LZ23 for 9 years now and I have my other trucks to drive when I am not working which are fun to drive themselves. What your looking at in the photo below is 8000lbs of rolling weight, truck weighs 3400lbs, that is 2000lbs on the flatbed, there is 2000lbs in the trailer, and the trailer weighs at least 600lbs likely more, this was just a normal day for me back then, and it was before power brakes, but I believe the trailer had electric brakes at that time. 5 Quote Link to comment
