Fuel sending unit wiring question.
serum114
  • Replies 5
2 hours ago, serum114 said:
Ok that makes sense, I saw the ground symbol on the wiring diagram so I wanted to be sure. Do you know if the fuel gauge should work while ignition is in “on” position or does the car need to be running? Thanks again!
It will be reading when the ignition is on.
