Madkaw Posted August 12, 2020 Report Share Posted August 12, 2020 1983 4wd with tilt wheel. I am so over this headlight switch. New switches are NLA for tilt wheel trucks this year. I actually took the guts out of a non tilt wheel and installed in my housing to try and rebuild my switch , but still doesn't work right all the time. Left headlight is dim when right is bright. I can remove the the switch off the column and operate the switch and get the left headlight to be bright by manually pushing on the contact. Its touching but not enough to hold full voltage at the headlight. headlight voltage is actually 11 volts while right side sees full voltage. Again, these are a new set of contacts . Bending them is about useless and about impossible to get right. Do others have issues with these NEW switches ? Are they all junk? I'm ready too install a non-tilt column so I can in stall a completely new switch since they are available . Also considering some toggle switches on the dash and completely deleting this archaic system. Its truly frustrating that this BS makes the truck useless at night . 1 Quote Link to comment
620slodat Posted August 14, 2020 Report Share Posted August 14, 2020 Have you tried using relays? Don 1 Quote Link to comment
Crashtd420 Posted August 14, 2020 Report Share Posted August 14, 2020 2 hours ago, 620slodat said: Have you tried using relays? Don If hes only getting 11volts that might not even be enough to trigger the relay.... 1 Quote Link to comment
banzai510(hainz) Posted August 14, 2020 Report Share Posted August 14, 2020 Crash Slowdat means: He means if he used a newer say common BLACK BOX the relay triggers at a lower voltage at like 6 volts then it would most likely work. Have to read the specs but some can trigger down at 3 VOLTS 1 Quote Link to comment
Crashtd420 Posted August 14, 2020 Report Share Posted August 14, 2020 15 minutes ago, banzai510(hainz) said: Crash Slowdat means: He means if he used a newer say common BLACK BOX the relay triggers at a lower voltage at like 6 volts then it would most likely work. Have to read the specs but some can trigger down at 3 VOLTS I was just looking to see if something like that existed but I wasn't sure if a relay triggered at 6volts would be able to carry the load of the headlights..... so I didnt want to suggest and add to his problems..... 1 Quote Link to comment
Crashtd420 Posted August 14, 2020 Report Share Posted August 14, 2020 Madkaw where are you getting the 11v reading? At the actual headlamp or coming off the switch directly? Reason I ask is because I'm thinking a possible ground issue.... Maybe turn them on and temporarily add an extra ground to the headlight and see if that helps or not... 1 Quote Link to comment
Madkaw Posted August 14, 2020 Author Report Share Posted August 14, 2020 Here’s the deal guys . I can drop the headlight switch off the column and actually push on the contact and the left headlight gets bright again . It’s near impossible to bend that tang so the contact works better . It makes contact , but not good enough- so I only get 11v at the headlight 2 Quote Link to comment
Charlie69 Posted August 14, 2020 Report Share Posted August 14, 2020 Can you build it up to put more pressure on it in the on position? Quote Link to comment
Crashtd420 Posted August 14, 2020 Report Share Posted August 14, 2020 1 hour ago, Madkaw said: Here’s the deal guys . I can drop the headlight switch off the column and actually push on the contact and the left headlight gets bright again . It’s near impossible to bend that tang so the contact works better . It makes contact , but not good enough- so I only get 11v at the headlight And if you just done messing with the switch then the relay might be your best option... Try a standard 12v automotive relay.... 11v might be enough to trigger it.... Cant hurt to try at this point.. . 1 Quote Link to comment
Crashtd420 Posted August 14, 2020 Report Share Posted August 14, 2020 And I just tried a relay with a 9volt battery and it triggered so 11v will work. 1 Quote Link to comment
Madkaw Posted August 15, 2020 Author Report Share Posted August 15, 2020 4 hours ago, Crashtd420 said: And I just tried a relay with a 9volt battery and it triggered so 11v will work. So your saying just use the power from the switch to run a relay to the headlights which would mean re-wiring the headlights 1 Quote Link to comment
Crashtd420 Posted August 15, 2020 Report Share Posted August 15, 2020 30 minutes ago, Madkaw said: So your saying just use the power from the switch to run a relay to the headlights which would mean re-wiring the headlights In a sense yes..... Switch would trigger the relay instead of outputting directly to the headlight.... I'm not 100% familiar with the way your headlights are setup but I would think it could be done just off the switch..... You have power, the trigger and the outputs right there.... I can advise more if needed, I'd have to look at the wiring and draw it up.... Quote Link to comment
Crashtd420 Posted August 15, 2020 Report Share Posted August 15, 2020 If you possible have a picture of the wiring diagram for you truck and could post a picture of the page that would help...I cant seem to find a good one online.... 1 Quote Link to comment
Lockleaf Posted August 15, 2020 Report Share Posted August 15, 2020 Your decent options all include wiring. If your 83 doesnt already have a headlight relay, the only downside is the work itself. Otherwise i would suggest swapping to a more available column and rewiring to use those switches. Otherwise haunt ebay for good used or NOS parts that fit. Or find that one guy on earth who refurbishes vintage car switch assemblies and pay whatever ransom he asks. 1 Quote Link to comment
Crashtd420 Posted August 15, 2020 Report Share Posted August 15, 2020 (edited) 3 hours ago, Madkaw said: So your saying just use the power from the switch to run a relay to the headlights which would mean re-wiring the headlights This is what I would do with just that one 11 volt wire...... Get a relay.... cut the 11v wire.... You'll also need a ground wire , And you should be able to get power from the switch input wire.... #85- ground #86- 11volt signal from switch #30- tap into the main power going. to switch .. #87- would go to the other half of the 11volt wire feeding power to the headlight.... Everything else should work as normal , this will simply amplify the weak 11v signal.... Edited August 15, 2020 by Crashtd420 Quote Link to comment
wayno Posted August 15, 2020 Report Share Posted August 15, 2020 Well I have been dealing with the 720 wiring harness for years, unless you want to make a completely new headlight wiring harness separate from the 720 wiring, you have to keep the stock headlight circuit stock, you cannot touch it in any way otherwise it screws stuff up. You cannot even put a aftermarket gauge in and wire it so the light comes on when you turn the headlights on unless you do it the way Nissan did it which has no ground wire to make it work, it is this complicated setup that has no ground until it gets to the headlight/headlamp relay, if any ground is added other than what Nissan did your introducing a ground where there is not supposed to be one. Madkaw, have you wired in any fog lights or aftermarket stereo lights? Have you used rubbing alcohol or the like to clean the contacts? Can you post a photo of the back of your column assembly, I have several in a container in my parts shed, maybe I have the one you need. Quote Link to comment
Madkaw Posted August 15, 2020 Author Report Share Posted August 15, 2020 From what I’ve read over the years , this seems to be an inherit problem with these switches . The solution is usually ratcheting the switch off and on quickly to get he contacts to seat properly and work correctly . I put all new contacts in an older housing and it still acts up. I think a better solution might be putting in a rocker switch for the headlights . Maybe wiring it a foot switch for the high beam switch. Of course I would use all the existing wires . Relays and heavier wires would be the ticket for better lighting for sure . All the power running thru that factory switch is just a bad design . Being able to do this would be a challenge to not screw up the original wiring . I think a separate circuit outside the OEM harness could be done as long as the coil side of the relays are in the circuit and nothing else Quote Link to comment
banzai510(hainz) Posted August 15, 2020 Report Share Posted August 15, 2020 (edited) will adding a H4 wire harness fix this???? then left wont be dim anymore but the orginal harness will trigger the new harness and run off the battery starter lug then the ground off the harness Edited August 15, 2020 by banzai510(hainz) 1 Quote Link to comment
Charlie69 Posted August 15, 2020 Report Share Posted August 15, 2020 I purchased a new aftermarket combination switch years ago from Rock Auto and used the new headlight switch parts out of it to fix my factory switch. Quote Link to comment
wayno Posted August 15, 2020 Report Share Posted August 15, 2020 Like I said, I have a few of these combination switches for tilt columns, the later stuff(after 1982) has a different plug going into it for the headlight part of the combination switch that I don't use, if you could post a photo. Here are a couple switches, is yours like either of these? 1 Quote Link to comment
Madkaw Posted August 16, 2020 Author Report Share Posted August 16, 2020 7 hours ago, Charlie69 said: I purchased a new aftermarket combination switch years ago from Rock Auto and used the new headlight switch parts out of it to fix my factory switch. That what I did also, but one of the contacts does not operate correctly .i bought a non tilt wheel switch and transferred all the guts . Actually when moving the connector around( bending the plastic housing ) changes the headlight performance . It’s the bottom contact that is moving or not contacting properly . 1 Quote Link to comment
Madkaw Posted August 16, 2020 Author Report Share Posted August 16, 2020 7 hours ago, wayno said: Like I said, I have a few of these combination switches for tilt columns, the later stuff(after 1982) has a different plug going into it for the headlight part of the combination switch that I don't use, if you could post a photo. Here are a couple switches, is yours like either of these? I’ll post a pic tomorrow . I got tired of screwing and put it back on . The truck goes for paint this week hopefully . 1 Quote Link to comment
Stinky Posted August 16, 2020 Report Share Posted August 16, 2020 (edited) Did you look at Autozone? Napa has one type and Autozone the other (tilt and non-tilt)...assuming that the year is right (I was looking for an 86). https://www.autozone.com/electrical-and-lighting/turn-signal-switch/duralast-turn-signal-switch-sw1687/293069_0_0 SW1687 is the PN...the only thing that I am using to identify it is the intermitant wiper lever. Edited August 16, 2020 by Stinky 1 Quote Link to comment
Madkaw Posted August 16, 2020 Author Report Share Posted August 16, 2020 I’m afraid to order anything else for 150$ and it not fit. I about get confused on what switch is correct for my truck . An 83 with tilt wheel seems thought to find . Many vendors describe choices as collapsible and not tilt. So is collapsible the same as tilt ? I don’t even care about tilt wheel , because for a tall guy I don’t even use it . In fact I wonder if the non-tilt is slimmer and gives more knee room under the claim shells ? I don’t want to swap out a complete column to get an available switch , but I might . I’m considering going with electric power steering and the non-tilt might make that easier to pull off 1 Quote Link to comment
Lockleaf Posted August 16, 2020 Report Share Posted August 16, 2020 If you want to see more on putting in a foot switch for high beams, see my 510 thread "half pint". I rewired the entire car with a modified 1982 720 wiring harness. I installed a foot high beam switch because my column switch doesn't work at and I'm too cheap to replace it when this works just as well. Collapsible means the column has a slip shaft in the middle so it collapses in an accident instead of being a spear aimed at your chest. 1 Quote Link to comment
