CicliDevotion Posted July 29, 2020 Report Share Posted July 29, 2020 I'm trying to source a new Headlight/Turn Indicator switch for my 1983 4X4 with tilt steering column. I am aware that the assembly for TILT is different than the one for FIXED column. Is there compatibility between other model years? Are 2WD and 4WD interchangeable? Should the new production from eBay/Thailand be avoided? Other source recommendations? 1 Quote Link to comment
NC85ST Posted July 29, 2020 Report Share Posted July 29, 2020 What’s wrong with the one you have? Unless it’s snapped in two, it generally can be taken apart and cleaned to restore function. 2wd and 4wd will interchange. I don’t think the year model makes a difference, I’m sure someone else will know for sure. 1 1 Quote Link to comment
