grannyknot Posted July 26, 2020 Report Share Posted July 26, 2020 I have a lead on a S62 R160 LSD diff. K on the top, 3.54:1 for $500 which sounds to me like a good deal but I have been reading that some of the later Subaru diffs don't fit into the square mounting hole on the rear cross member of a 510. Is that true and if so is there a cut off date I should be looking for or outside makings on the diff that will tell me? I'll take a tape measure with me for sure, this diff appears to have the bolt in side axles same as the original diff. This is the only pic the seller has, Quote Link to comment
thisismatt Posted July 26, 2020 Report Share Posted July 26, 2020 That's an R180, not an R160. Never heard of any problems fitting into the cross member. Quote Link to comment
datzenmike Posted July 26, 2020 Report Share Posted July 26, 2020 Pretty sure the K makes it a later 180. I had one from a later 720 truck. Traded it for some disc brake rotors to a 510 guy who wanted 4.11s Quote Link to comment
thisismatt Posted July 26, 2020 Report Share Posted July 26, 2020 20 minutes ago, datzenmike said: Pretty sure the K makes it a later 180. I had one from a later 720 truck. Traded it for some disc brake rotors to a 510 guy who wanted 4.11s Not just the K but the mustache mount is a solid plane unlike the R160, as well as the wider spacing of the rear cover top bolts and the fat shoulders of the case where the cover mounts. 1 Quote Link to comment
grannyknot Posted July 27, 2020 Author Report Share Posted July 27, 2020 Well the engine/trans in the 510 will be a KA24DE and 5 spd from an S13 240sx which I think had a final ratio of 4.08:1 If I install this R180 LSD with a 3.54:1 ratio 1st gear will be useless with lousy acceleration although good mileage on the highway. I think the stock R160 is diff is 3.90:1 so maybe I would be better off not buying this Subie R180. What do you guys think? Quote Link to comment
datzenmike Posted July 27, 2020 Report Share Posted July 27, 2020 The R-160 will handle a KA if you don't go insane on it. While enjoying your ride keep your eyes peeled for a better set of R-180 gears. Quote Link to comment
banzai510(hainz) Posted July 27, 2020 Report Share Posted July 27, 2020 (edited) I have a early type Sube R160 and its a 3.70 and use the 510 stubs I think a 3.50 is just too high a GR But I could be wrong with a KA. If you lived in germany on the Autobahn might be perfect Edited July 27, 2020 by banzai510(hainz) 1 Quote Link to comment
demo243 Posted July 27, 2020 Report Share Posted July 27, 2020 (edited) Nothing wrong with an R160 behind a KA as long as you dont plan on doing burnouts all the time. The issue with the Subi diffs fitting through the cross member is due to the round driveshaft flange - swap it to the rectangular one from your diff and its all good. 3.54 is going to be really slow, even behind a KA. I run a 4.11 mostly and have a 4.44 in it right now. 4.11 has been my favorite ratio to date - quick enough for fun acceleration, but not rev'ed to high at 80 on the highway. If you can find one --- find one of the early 80's Subaru clutch pack LSDs (CLSD) --- most of them were 3.7s, but you can pull the clutch pack center unit and drop it into any other r160 (even the newer ones, which opens up easier to find gearing options --- ie my 4.44 came from a 2000's forester, but then I used the older center unit in it to adapt it back to the datsun stub axles. Edited July 27, 2020 by demo243 Quote Link to comment
grannyknot Posted July 27, 2020 Author Report Share Posted July 27, 2020 Thanks guys, sound advice. If I'm reading the ring gear stamped numbers correctly then this R160 is already 4.11 which is exactly what the 240sx engine/trans want. I'll keep my eyes peeled though. Quote Link to comment
