1lo620 Posted July 20, 2020 Report Share Posted July 20, 2020 I am in need if a bolt that goes into the brake cylinder and that the bleeder bolt goes into. I had one break off on me. It is for a 74 620 front left if that matters. Any help would be appreciated.. Quote Link to comment
KDW_80-720 Posted July 20, 2020 Report Share Posted July 20, 2020 You might take it with you to a hydraulic/fitting shop local to you. I see you're in Renton, I know in Seattle there is Pacific Rubber, might now be the Alaska Rubber group. You might call and see if they do brake lines, or can recommend another hose shop that does up there, Quote Link to comment
1lo620 Posted July 20, 2020 Author Report Share Posted July 20, 2020 Thanks for the advice. I use to live in Renton but I know live in San Antonio Texas. Quote Link to comment
banzai510(hainz) Posted July 21, 2020 Report Share Posted July 21, 2020 (edited) Orilelys use to have a brake bleed assortment kit with various bleed nuts in them.i found a set for my 521 that fit but 521s are SAE but I’m sure there is a metric set in there. i think it was like a HELP kit. the longer bolt/brake hydraulic part you need to find a spare from somebody or try eBay Edited July 21, 2020 by banzai510(hainz) Quote Link to comment
1lo620 Posted July 21, 2020 Author Report Share Posted July 21, 2020 Bleeder screw I have..it broke off in the bolt that goes into the brake cylinder. That is what I am looking for ..the part that the bleeder screw goes into Thanks Hainz..hope your well. Quote Link to comment
Crashtd420 Posted July 21, 2020 Report Share Posted July 21, 2020 Your probably going to have to buy a new wheel cylinder to get it... Quote Link to comment
datzenmike Posted July 21, 2020 Report Share Posted July 21, 2020 Drill it, heat with a torch and use an easy out. This would make you superior to a mechanic these days who only know how to replace shit.... never how to fix anything. 2 Quote Link to comment
Crashtd420 Posted July 21, 2020 Report Share Posted July 21, 2020 23 minutes ago, datzenmike said: Drill it, heat with a torch and use an easy out. This would make you superior to a mechanic these days who only know how to replace shit.... never how to fix anything. I was going to suggest that but most dont have easy out tools available... they are a worthwhile investment.... The small ones like to break so use a lot of heat and pay attention or you'll have a broken easy out in your broken bleeder.... I just figure for $15, which I cheaper than buying an easy out set, just use the bleeder and y fitting and throw the wheel cylinder on the shelf.... Quote Link to comment
datzenmike Posted July 21, 2020 Report Share Posted July 21, 2020 There is that. Also some owners will have some tools and a set of easy outs can come in handy again and again. Quote Link to comment
1lo620 Posted July 21, 2020 Author Report Share Posted July 21, 2020 Well the wheel cylinder that I bought which what is what I was replacing didn't come with that bolt. Just the bleeder bolt. I was going to try to drill it out but I don't have a easy out set. I made look and see if I can find a brake cylinder that comes with that part. I have multiple 620s so having it as back up wouldn't hurt. Quote Link to comment
]2eDeYe Posted July 21, 2020 Report Share Posted July 21, 2020 Mail that thing to me I'll get it out for ya. Quote Link to comment
