garryk6 Posted July 13, 2020 Report Share Posted July 13, 2020 (edited) Here is my little SoCal find I acquired back in around 2001. It had been chopped up with Toyota running gear. Later I found a running driving L-320 with a J13 that a tree had fallen on the drivers cab so the top was cut off and the door removed and used as a yard truck till I bought it from Chino CA. In 2002/2003 I removed the body from the chopped up NL chassis and parted out the body from the L truck then removed the two unique NL body mounts from the NL frame and welded them to the L Chassis. Remounted the NL to the original L chassis and now have a near original truck. It ran and drove in 2003-2007 around the yard with the hand brake to stop and no lights connected. So now I need to do that and get the engine running again as it has sat since 2007 in storage at my dads farm. In 2005 or 2006 a few of us had a limited run of taillight lenses made. I found my set as I was going thru my part’s this weekend. Can’t wait to get this little rust free baby truck back on the road!! Garry Edited July 21, 2020 by garryk6 7 Quote Link to comment
320 Newb Posted July 13, 2020 Report Share Posted July 13, 2020 Can't wait to see this come together. Let us know how we can help. 2 Quote Link to comment
Draker Posted July 13, 2020 Report Share Posted July 13, 2020 very cool! Really love the NL! 1 Quote Link to comment
difrangia Posted July 13, 2020 Report Share Posted July 13, 2020 That will be one nice ride; big smiles every time you drive it !! The two old trucks that really wind my key are the NL320 and the 1961-63 Ford Uni-Body pickups. The Ford needs to be short bed with big back window; a really rare combination. 2 Quote Link to comment
garryk6 Posted July 14, 2020 Author Report Share Posted July 14, 2020 Thanks everyone! Tonight I pulled the four rally rims off and put three roller 700x15’s from an old trailer and a new 195-65-15 that will become the matching spare. I put the rally wheels an four take-off Michelin 195-65-15 tires from my wife’s Jetta back in 2001. Three would hold air but were so cracked I wasn’t sure how long they would even hold air. The fourth held air long enough to winch on the trailer and then again to get it off. I won’t be able to move the NL till I replace the right front roller 700x15 as it will only fit under the fender with the wheel tuned just right. LOL. So I’ll be on the lookout for a decent set of 195-65-15 tires or a sale on new ones soon. Well time to get to bed. 4:00am comes mighty early! Garry in Ellensburg 2 Quote Link to comment
Stoffregen Motorsports Posted July 19, 2020 Report Share Posted July 19, 2020 I just threw away a set of original 620 wheels and tires. The tires were not cracked, and still had plenty of tread, but they were original. I tried to give them away here on Ratsun, but nobody wanted them. FYI - if you want a "plus one" look on the wheels, find a set of solid axle Toyota 4x4 (pickup and LC) wheels. They are 15" and slightly wider than the stock Datsun wheels and some even have nubs for hubcaps. 1 Quote Link to comment
Stoffregen Motorsports Posted July 19, 2020 Report Share Posted July 19, 2020 These guys went to the extreme and started machining their own proprietary billet wheels to look like stock Toyota wheels. Super cool - https://store.fj.co/products/the-fjco-expedition-wheel-6-lug 1 Quote Link to comment
Stoffregen Motorsports Posted July 19, 2020 Report Share Posted July 19, 2020 1 Quote Link to comment
EDM620 Posted July 19, 2020 Report Share Posted July 19, 2020 I have a full set of original 620 slotted alloy wheels on classifieds and I also have a set of 5 steel wheels from a 720 - same bolt pattern 14" diameter 2 Quote Link to comment
Charlie69 Posted July 20, 2020 Report Share Posted July 20, 2020 I have never heard of 620 factory alloys. Please educate me? 1 Quote Link to comment
EDM620 Posted July 21, 2020 Report Share Posted July 21, 2020 Optional on the 620 series, I honestly don't know if from the factory or dealer but Datsun center caps originally. 1 Quote Link to comment
garryk6 Posted July 28, 2020 Author Report Share Posted July 28, 2020 Hey guys and gals! I finally found the key to the NL 320. She has new tires on her, charged a battery and at first the starter just spun but no engaging. I love the little bypass button on the solenoid. Was able to crank and lovingly tap with a hammer and then the Hendrix engaged and she was cranking. I had already disconnected the fuel line, connected to an outboard fuel tank and primed the carb. But cranked and no fire. No spark at the points but power to and through the coil down to the points. I’m thinking I have a bad condenser. Any thoughts? Thanks again!! Garry 2 Quote Link to comment
wayno Posted July 28, 2020 Report Share Posted July 28, 2020 (edited) To be honest I hate 320 distributors, they have given me nothing but headaches, I get it working and the engine running, but the next time I try to start it it has no spark again, I finally gave up on my distributor in the 1963 and bypassed the stock wiring(positive ground) and used a modified matchbox distributor in it and it started right up better than it ever had before, but that was only a temporary experiment to see if things got better and they did so I knew it was that crap distributor. Then one day I was tearing down a MG Midget engine as I had no nibbles on it after putting it on craigslist, I took out the EI distributor and just stared at it, it looked just like the 320 distributor, so I pulled that crap 320 distributor out again and dropped this MG Midget electronic ignition distributor in it and it fit like it was made for it, so I bypassed the stock wiring again and timed it and wired it to run, and it started right up, but this didn't fix the positive ground issue, this MG Midget distributor had a Crane ignition in it, so while I was talking about this Crane Ignition system on my thread and about how I could hardly find anything about it another member chimed in with a link, it was about this Crane EI system, so while I was reading I came across a diagram that showed how to wire the Crane IE system positive ground, I put it back in the 320 again and wired it exactly the way it said to wire it and then started it, I could not believe it, it was wired positive ground and it ran great and it was charging, it started the easiest it ever had in all the time I owned the truck(years), I have never removed it since and after sitting months it starts right up without any issues once I charge the battery(old battery), keep in mind that all my classics have non-ethanol gas it them, so the gas does not spoil. Edited July 28, 2020 by wayno 1 Quote Link to comment
difrangia Posted July 28, 2020 Report Share Posted July 28, 2020 Clock !! Check the insulator that isolates the bolt that transfers current from coil to the points where it goes through the distributor body. Someone had shadetreed mine and it shorted out going down the road which put me walking. Came up with a suitable insulator and drove it for the next year with no spark problems. 2 Quote Link to comment
garryk6 Posted July 28, 2020 Author Report Share Posted July 28, 2020 37 minutes ago, difrangia said: Clock !! Check the insulator that isolates the bolt that transfers current from coil to the points where it goes through the distributor body. Someone had shadetreed mine and it shorted out going down the road which put me walking. Came up with a suitable insulator and drove it for the next year with no spark problems. I’ll look into it. It was running 12 years ago when I put it in storage. But anything is possible 1 Quote Link to comment
garryk6 Posted July 28, 2020 Author Report Share Posted July 28, 2020 15 hours ago, wayno said: To be honest I hate 320 distributors, they have given me nothing but headaches, I get it working and the engine running, but the next time I try to start it it has no spark again, I finally gave up on my distributor in the 1963 and bypassed the stock wiring(positive ground) and used a modified matchbox distributor in it and it started right up better than it ever had before, but that was only a temporary experiment to see if things got better and they did so I knew it was that crap distributor. Then one day I was tearing down a MG Midget engine as I had no nibbles on it after putting it on craigslist, I took out the EI distributor and just stared at it, it looked just like the 320 distributor, so I pulled that crap 320 distributor out again and dropped this MG Midget electronic ignition distributor in it and it fit like it was made for it, so I bypassed the stock wiring again and timed it and wired it to run, and it started right up, but this didn't fix the positive ground issue, this MG Midget distributor had a Crane ignition in it, so while I was talking about this Crane Ignition system on my thread and about how I could hardly find anything about it another member chimed in with a link, it was about this Crane EI system, so while I was reading I came across a diagram that showed how to wire the Crane IE system positive ground, I put it back in the 320 again and wired it exactly the way it said to wire it and then started it, I could not believe it, it was wired positive ground and it ran great and it was charging, it started the easiest it ever had in all the time I owned the truck(years), I have never removed it since and after sitting months it starts right up without any issues once I charge the battery(old battery), keep in mind that all my classics have non-ethanol gas it them, so the gas does not spoil. That’s my goal later on is to convert to EI with MG parts. Someone already converted to negative ground so makes choices easier. Thanks for the help. I am hoping to get it done and on the road by fall. Garry 1 Quote Link to comment
wayno Posted July 28, 2020 Report Share Posted July 28, 2020 If you are already converted to negative ground then you can use a Matchbox distributor unless your truck is RHD, Mike did it in his NL320 thread, look at the first page, he shows how to change out the drive on the shaft. 1 Quote Link to comment
320 Newb Posted July 28, 2020 Report Share Posted July 28, 2020 3 hours ago, garryk6 said: That’s my goal later on is to convert to EI with MG parts. Someone already converted to negative ground so makes choices easier. Thanks for the help. I am hoping to get it done and on the road by fall. Garry I converted to a MG distributor and MG starter. They both look stock but perform better. For the distributor I'm using a rebuilt 1960s Lucas 25D and it drops right in, no mods needed, same hold down clamp and everything. They also make a Lucas 25D electronic dizzy if you want to go that route. 2 Quote Link to comment
garryk6 Posted July 28, 2020 Author Report Share Posted July 28, 2020 1 hour ago, 320 Newb said: I converted to a MG distributor and MG starter. They both look stock but perform better. For the distributor I'm using a rebuilt 1960s Lucas 25D and it drops right in, no mods needed, same hold down clamp and everything. They also make a Lucas 25D electronic dizzy if you want to go that route. Does the 45D fit like the 25D? Just curious if anyone knows or not. Thanks again!! 1 Quote Link to comment
wayno Posted July 29, 2020 Report Share Posted July 29, 2020 (edited) I believe mine is a 45D with a XR3000 Crane ignition (wired positive ground), I also have my extra J15 engine on a stand using the 45D with a XR700 Crane ignition in it(wired negative ground). If your negative ground I would likely go with a Matchbox if you can find one and use your drive key on it, otherwise there are a bunch of cheap MG Midget distributors on ebay. This is the type of setup I have on my extra J15 engine, but they want way too much money for it, I would not buy it. https://www.ebay.com/itm/Lucas-MGB-Electronic-Ignition-Distributor-41695-41695A-Cap-Wires-Crane-Cam-XR700/163353504837?hash=item2608a0ac45:g:8EkAAOSwiwZb3hiz Matchbox is the way to go if negative ground. Edited July 29, 2020 by wayno 1 Quote Link to comment
difrangia Posted July 29, 2020 Report Share Posted July 29, 2020 (edited) Matchbox dizzys are nice, but I used the remote ECM 1978 Datsun 620 distributor on my E1 with a mid 80's GM module mounted remotely. Converted the 78 'Bulletside' to the remote GM ECM also. Tried to use as many common parts for the 78 'Bulletside' and the 320 as I could so I could stock as few common parts as possible for future maintainence. The little 320 and the 620 hasn't missed a beat in over four years. How much will a Matchbox ECM or Nissan remote ECM set you back ?? GM's are bout 12-13 USD. Edited July 29, 2020 by difrangia 1 Quote Link to comment
stevecar Posted July 29, 2020 Report Share Posted July 29, 2020 Garry, Any info on the clock? Do you think it is the correct clock option? You might have to do some detective work. Steve 2 Quote Link to comment
garryk6 Posted July 29, 2020 Author Report Share Posted July 29, 2020 14 hours ago, stevecar said: Garry, Any info on the clock? Do you think it is the correct clock option? You might have to do some detective work. Steve It is the factory clock and radio. I got the truck from owner number two who purchased it from his neighbor owner number one. It matches the information posted here on that NOS clock from THAILAND. Quote Link to comment
wayno Posted July 30, 2020 Report Share Posted July 30, 2020 I was sent this photo in an email today. 1 Quote Link to comment
garryk6 Posted July 30, 2020 Author Report Share Posted July 30, 2020 Some pictures of my parts treasure trove of Datsun parts to restore the NL and some to sell later on. 4 Quote Link to comment
