DPW Posted July 13, 2020 Report Share Posted July 13, 2020 Hello, Has anyone put 17"x8" 0" offset wheels on a 510 2 door with BRE fender flares front and rear? My car is a 1969 Datsun 510 2 Door. For street use and Autocrossing and general fun. I am finally getting close to finishing this project after 35+ years. I have the following modifications: 5x114.3 (5x4.5") bolt pattern Troy Ermish Inc. Stage 2 coilover suspension, 280ZX Struts 1” Knuckle Risers Adjustable Lower Control Arms Larger Rod Ends Adjustable T/C Rods Modified Steering Arms Idler Arm with Delrin Bushings 280ZX big Wilwood disc brakes front 1 1/8” Datsun Competition Front Sway Bar Wilwood disc brakes rear 7/8” Rear 3-Way Adjustable Sway Bar BRE Fully Adjustable Rear Crossmember Tires I am looking to use are 215/45ZR17 (94Y) XL or 225/45ZR17 Michelin Pilot Sport 4S tires. Thanks Don Quote Link to comment
iceman510 Posted July 13, 2020 Report Share Posted July 13, 2020 Have you calculated your overall diameter difference/increase with your proposed tire size? What is the largest wheel/tire package you have had on it? I have 15 x 7 0 offset VTO wheels I will be putting an a BRE flared car. I have not measured yet to see if it could take a half inch more each in the inboard/outboard directions which is what you would essentially be doing with an 8 inch wide wheel. I think an 8" zero offset should fit in a 15" diameter wheel. My concern with the 17" overall wheel and tire diameter is whether you would be getting tall enough to now get close the the flare and or sheet metal as it curves in to meet the original fender location. Quote Link to comment
Jesse C. Posted July 26, 2020 Report Share Posted July 26, 2020 These are 16" Watanabe wheels on my 510 with BRE flares. I believe the rims are 8 inches wide and I do not remember the offset. The rims belonged to a friend and he just let me try them out. I am currently going to use 15X10 and 15X8 Hoshino Impuls on it 1 Quote Link to comment
demo243 Posted August 8, 2020 Report Share Posted August 8, 2020 Do you really want a 17” wheel on a 510? What engine and rear diff are you running? That’s a tall tire for autocross— most people go shorter for quicker acceleration. Quote Link to comment
