grannyknot Posted July 9, 2020 Report Share Posted July 9, 2020 I'm putting a KA24DE in my 510 so was setting up to cut the center out and reverse it but now I'm thinking the PO has already drilled out the inserts and welded them reversed. Thought I would check with you guys. Thanks, Quote Link to comment
Draker Posted July 10, 2020 Report Share Posted July 10, 2020 The lower control arms usually mount on the backside of the cross member. So if the lower taper bolt goes into the front side, then yeah, it's already been flipped. Quote Link to comment
Draker Posted July 10, 2020 Report Share Posted July 10, 2020 And by just looking at your picture, the U bend is facing the rear, allowing for a front mount (KA) oil pan. Quote Link to comment
grannyknot Posted July 10, 2020 Author Report Share Posted July 10, 2020 Oh man I'm so glad I checked, if I had cut it up, reversed it and welded it back only to find it I had just buggered it up 😠 Thanks Quote Link to comment
