J's 620 Posted August 27, 2020 Author Report Share Posted August 27, 2020 When the cam gets back to me I’ll have to get some measurements. I’m curious to see what kind of lift and duration it will actually have and how they achieved that. I’ll post up pics as well Quote Link to comment
datzenmike Posted August 27, 2020 Report Share Posted August 27, 2020 Cam makers show lift and duration at 0.050" lift whereas Nissan just specifies absolute lift, lobe - base circle. The L20B cam is 0.413" valve lift and 2480duration. I would love to know what an L20B cam is at 0.050" lift but it will be less than those numbers. By grinding down the base circle the duration and lift are increased. I have an Isky cam marked L -0.490 09 7101 It has 0.480" total lift. I just measured it Quote Link to comment
Stoffregen Motorsports Posted August 27, 2020 Report Share Posted August 27, 2020 On 8/24/2020 at 7:11 AM, banzai510(hainz) said: Delta Cams were never right the ones I got. I NEVER USED THEM. Cal Cams has all the modern L series cams. At least they should, but they may be proprietary and you may need to buy through Rebello. I don't think Isky has designed a new cam for the L motor since the 80's. 1 Quote Link to comment
J's 620 Posted August 27, 2020 Author Report Share Posted August 27, 2020 So if my delta comes back as a real turd go with an isky or a cal cams through to robello? I really just want a slight increase in lift and duration over stock, nothing crazy it’s still a street truck. I asked for a 272 grind for a bit more top end to compete on the freeways. It’s a 4 spd Quote Link to comment
datzenmike Posted August 27, 2020 Report Share Posted August 27, 2020 With the 4.11 differential and stock tires... @ 60 that's 3,400 RPMs @ 65 that's 3,700 @ 70 that's just under 4,000 If the cam starts to really work above 4K you may not be able to use it. Quote Link to comment
J's 620 Posted August 28, 2020 Author Report Share Posted August 28, 2020 19 hours ago, datzenmike said: With the 4.11 differential and stock tires... @ 60 that's 3,400 RPMs @ 65 that's 3,700 @ 70 that's just under 4,000 If the cam starts to really work above 4K you may not be able to use it. I kinda remember the guy saying the range was 2000-5000 rpm on the cam. I’ll call today and confirm that. My tire size is 205/70/15 Quote Link to comment
J's 620 Posted August 28, 2020 Author Report Share Posted August 28, 2020 The 272 grind is supposed to be a mild cam Quote Link to comment
J's 620 Posted August 28, 2020 Author Report Share Posted August 28, 2020 Oh and mike, my truck doesn’t have a tach, so I never know what my rpms are and my speedo seems to be less accurate the faster I go. Quote Link to comment
banzai510(hainz) Posted August 28, 2020 Report Share Posted August 28, 2020 yeah call him and say what I sad about the cams I bought. You want lift also and make sure to grind it and measure it and times 1.4891.5 or your not buying it. hope you have thicker lash pads and maybe taller retainers Quote Link to comment
J's 620 Posted August 28, 2020 Author Report Share Posted August 28, 2020 9 minutes ago, banzai510(hainz) said: yeah call him and say what I sad about the cams I bought. You want lift also and make sure to grind it and measure it and times 1.4891.5 or your not buying it. hope you have thicker lash pads and maybe taller retainers Thanks hainz, I will tell him exactly what you’ve been saying. I’m counting on the shop to get the lash pads and retainers, I just don’t know where to get those items. I’m going to drop by today and check on the progress, and show them the coolant passages to drill into the head for the particular manifold I will now be running. It’s from an 80’ 720. Quote Link to comment
J's 620 Posted August 28, 2020 Author Report Share Posted August 28, 2020 Is there anything they need to know about drilling those coolant passage holes? Any do’s/dont’s??? Quote Link to comment
J's 620 Posted August 28, 2020 Author Report Share Posted August 28, 2020 so here’s what I was told over the phone. The 272 is a 218 duration at .050, 435 lift. no need for taller lash pads or retainers, 1800 and up on rpm. It’s a mild cam, the next one up needs stiffer springs, so the 272 will allow me to re use all my current components. I will have the shop verify these numbers or I won’t buy that cam. Quote Link to comment
banzai510(hainz) Posted August 28, 2020 Report Share Posted August 28, 2020 (edited) the head coollant passage I just take a intake gasket and drill a 1/4 inch hole enough to pass water thru there. However if one lives in a hot climate I would leave the head alone and keep it solid and one don't have to worry about water leaks from that again. One just has to plug the water out let under the fuel pump. Most people just cut the rubber line and but a bolt in there and clamp it I have a 460lift 270 Schneider and really this should have come stock in datsuns minues the valve last its about 450 if that on lift. Notice the 1/4 inch water passage I drilled U67 head Edited August 28, 2020 by banzai510(hainz) Quote Link to comment
J's 620 Posted August 28, 2020 Author Report Share Posted August 28, 2020 I live in east idaho, we get both extremes, cold and hot, I think for winter it would be better to have coolant flow through that manifold to warm up easier. Quote Link to comment
J's 620 Posted August 30, 2020 Author Report Share Posted August 30, 2020 I see some evidence of cavitation in my front cover. Quote Link to comment
J's 620 Posted August 30, 2020 Author Report Share Posted August 30, 2020 It actually looks worse in person, the picture down plays the depth in some areas. Quote Link to comment
J's 620 Posted August 30, 2020 Author Report Share Posted August 30, 2020 Timing guides and the tensioner. The grooves are maybe 1/8” deep, slightly more than that possibly. Quote Link to comment
Stoffregen Motorsports Posted August 30, 2020 Report Share Posted August 30, 2020 The timing cover doesn't look bad at all. As long as there aren't any holes in it, I'd run it. New coolant will help keep the porosity from getting worse. Obviously you're replacing the timing chain guides and tensioner, right? Quote Link to comment
J's 620 Posted August 30, 2020 Author Report Share Posted August 30, 2020 18 minutes ago, Stoffregen Motorsports said: The timing cover doesn't look bad at all. As long as there aren't any holes in it, I'd run it. New coolant will help keep the porosity from getting worse. Obviously you're replacing the timing chain guides and tensioner, right? I was hoping it was still good to use, there are no holes. Besides I wouldn’t expect to find a front cover these days. ITM brand is what my timing set is. I’m replacing all the components. I’m already there might as well. 1 Quote Link to comment
J's 620 Posted August 30, 2020 Author Report Share Posted August 30, 2020 I’m basically ready for the head to come back from the shop, I want to get it running again. 1 Quote Link to comment
banzai510(hainz) Posted August 31, 2020 Report Share Posted August 31, 2020 Somebody might have a timing cover. maybe you could JB weld the pits but that's me. and I acutua;ly had a hole it was so tiny and water in the oil pan once it pressurized up Quote Link to comment
datzenmike Posted August 31, 2020 Report Share Posted August 31, 2020 On 8/28/2020 at 8:12 AM, J's 620 said: so here’s what I was told over the phone. The 272 is a 218 duration at .050, 435 lift. no need for taller lash pads or retainers, 1800 and up on rpm. It’s a mild cam, the next one up needs stiffer springs, so the 272 will allow me to re use all my current components. I will have the shop verify these numbers or I won’t buy that cam. Stock duration is 248 but I doubt it's measured at the standard 0.050" lift most cam makers do. Someone needs to have an L cam measured so we are comparing apples to apples. Quote Link to comment
J's 620 Posted August 31, 2020 Author Report Share Posted August 31, 2020 I was looking at my water pumps today and realized I have a different water pump altogether then what I want to run now. Quote Link to comment
J's 620 Posted August 31, 2020 Author Report Share Posted August 31, 2020 The one on the left : it’s what I was running before I tore it apart, I beleive it’s a 240z pump but not sure. The one on the right: it’s what I plan on using. It’s this part # (pic below) Quote Link to comment
J's 620 Posted August 31, 2020 Author Report Share Posted August 31, 2020 this is the ‘S10’ water pump pulley I was running with that water pump that I think was for a 240z. It’s bolt holes are way off for the AW9009. Quote Link to comment
