datzenmike Posted March 31, 2021 Report Share Posted March 31, 2021 Then there's bird turds. 1 Quote Link to comment
Lockleaf Posted March 31, 2021 Report Share Posted March 31, 2021 I bet if you cut that bumper down from the like 5-6 inches deep it is currenty, to more like 1.5-2 inches deep and tucked it up real close to the body it would look really nice. Not quite the bumperettes look that many 521 guys really like, but it might make a silk purse out of a sows ear. Maybe even leave the outer ears longer and shape them nicely so they wrap around the edges of the body some? Maybe it's just me though. I am a huge fan of making stuff out of what I have or others reject as garbage. 1 Quote Link to comment
CollinMB Posted March 31, 2021 Author Report Share Posted March 31, 2021 Personally, it's one of those things where it's not to my taste, but it's too nice to just toss or cut up. I'd rather sell it to someone that wants it and I'm planning to eventually just make my own bumpers 2 Quote Link to comment
CollinMB Posted April 16, 2021 Author Report Share Posted April 16, 2021 (edited) Update. All the stock front suspension and lines are out: I'm planning to start cutting the mounts off of the frame tomorrow and start prepping the Miata subframe to be notched Edited April 16, 2021 by CollinMB 1 Quote Link to comment
CollinMB Posted April 19, 2021 Author Report Share Posted April 19, 2021 ...and stock mounts are out: I cleaned off as much of the surface paint and pitting as I could. hit it with a scotchbrite pad, cleaned with acetone and threw a couple of coats of weld through primer on each side for good measure. Going to start taking measurements and marking up the Miata subframe to be notched this week. Depending how smooth things go, I may have the subframe welded in by the end of the week. 3 Quote Link to comment
greenthumb Posted April 20, 2021 Report Share Posted April 20, 2021 Sounds exciting! No more kingpin bs for you 2 Quote Link to comment
CollinMB Posted April 20, 2021 Author Report Share Posted April 20, 2021 So I've made the decision to adjust plans slightly. For a lot of my design reference I've been basing my design along the same lines of Bob3's Project MX520. In his build he coped the truck frame and Miata subframe in order for the two to mate up. I'm sure it's plenty strong enough, but as opposed to his build that was oriented around road racing, I'm planning to build my truck into more of an off-road adventure vehicle. So instead of attaching the subframe to the truck frame, I'm planning to attach the Miata strut towers to the frame and keep the subframe as a bolt on affair. This will also allow me to more easily swap to a tubular subframe in the future if I wish to do a different powerplant. I did a quick mock up of how I plan to attach the strut towers: This should give me plenty of strength to beat on. 1 Quote Link to comment
CollinMB Posted April 27, 2021 Author Report Share Posted April 27, 2021 So walking back my last statement and taking even further measurements, research, big brain activity, I decided to cut the subframe after all. Part of the reason being it was going to be more complicated to attach the strut mounts to the chassis. Also, it will be easier to lift the cab off in the future. More on that in a bit. So, down to work: I took copious measurements, notched the subframes in the appropriate locations, offered it up to the frame, did more trimming, and finally got it mounted, level, and straight. Welded in: And just like that, it's in. I did have to go back and fix one spot that was too far out of tolerance for my liking. Back to the point of lifting off the cab; whereas the welds are very strong (I did some stress testing just to make sure) I would like to go back and add reinforcement plates, but in the future. Why in the future? Because I would like to MIG the rest as opposed to using the flux I did for this. I'm doing all of this work in a carport that's open on both sides, which means the air blows right through. I threw a couple coats of black on the frame and moved forward for now. Current situation: I got most of the front suspension back together. For now the plan is to get it to a roller and I'll get back to doing finish work once I have actual garage space (hopefully in the not too distant future). Pretty soon I can work on getting the engine mounted and get the truck turned around and start working on the rear subframe. At this point I have accumulated quite the mess of stock parts that came off the truck, so I am going to switch some concentration to getting stuff cleaned up and sold. 4 Quote Link to comment
mrbigtanker Posted April 28, 2021 Report Share Posted April 28, 2021 Looking good, love it. 1 1 Quote Link to comment
Charlie69 Posted April 28, 2021 Report Share Posted April 28, 2021 I have to agree with Mr Tanker, Looking Good!!! 1 Quote Link to comment
greenthumb Posted April 28, 2021 Report Share Posted April 28, 2021 So now the Frankenjob to support the top of the strut? What’s your plan for that? love this idea! 1 Quote Link to comment
CollinMB Posted April 28, 2021 Author Report Share Posted April 28, 2021 6 minutes ago, greenthumb said: So now the Frankenjob to support the top of the strut? What’s your plan for that? love this idea! Eventually I'll be grafting I them into the wheel wells/engine bay 1 Quote Link to comment
thisismatt Posted April 28, 2021 Report Share Posted April 28, 2021 1 hour ago, greenthumb said: So now the Frankenjob to support the top of the strut? What’s your plan for that? love this idea! Square tube of various sizes and various angles ftmfw 1 Quote Link to comment
CollinMB Posted September 28, 2021 Author Report Share Posted September 28, 2021 Quick Update: With temps finally cooling down we moved my 521 over to my buddy's place so we can get back to making some progress on the drivetrain swap. 3 Quote Link to comment
CollinMB Posted October 12, 2021 Author Report Share Posted October 12, 2021 Truck update. My buddy and I started a YouTube to do the truck build and some racing stuff. If you like it, check it out. If YouTube isn't your thing, I'll post some random updates here and there as well. 1 Quote Link to comment
mrbigtanker Posted October 14, 2021 Report Share Posted October 14, 2021 were are you guys located in SoCals Quote Link to comment
CollinMB Posted October 14, 2021 Author Report Share Posted October 14, 2021 2 minutes ago, mrbigtanker said: were are you guys located in SoCals My buddy's place is in Chino and I'm in the process of moving Quote Link to comment
mrbigtanker Posted October 14, 2021 Report Share Posted October 14, 2021 2 minutes ago, CollinMB said: My buddy's place is in Chino and I'm in the process of moving Shit man I live in Eastvale,im 1 minute from you Quote Link to comment
CollinMB Posted October 14, 2021 Author Report Share Posted October 14, 2021 1 minute ago, mrbigtanker said: Shit man I live in Eastvale,im 1 minute from you I know, I bought my headlights and tonneau cover from you XD 1 Quote Link to comment
mrbigtanker Posted October 14, 2021 Report Share Posted October 14, 2021 29 minutes ago, CollinMB said: I know, I bought my headlights and tonneau cover from you XD I am losing it.lol Thats right . 1 1 Quote Link to comment
Stoffregen Motorsports Posted October 14, 2021 Report Share Posted October 14, 2021 Oil vapor getting to you? or just old age? 2 Quote Link to comment
mrbigtanker Posted October 14, 2021 Report Share Posted October 14, 2021 52 minutes ago, Stoffregen Motorsports said: Oil vapor getting to you? or just old age? I think a little of both.lol 1 1 Quote Link to comment
CollinMB Posted December 14, 2021 Author Report Share Posted December 14, 2021 (edited) Update on the truck, engine is in Edited December 16, 2021 by CollinMB Quote Link to comment
