The Fake Datsun utility trailer
About 11 years ago I purchased a utility trailer to help with hauling kayaks and camping gear.
This is what it looked like when I bought it. It was always left outside and had a rotten wood deck under blue aqua turf.
In less than a year I had put a new piece of plywood down for the floor and made these really simple side boards. I also installed new LED tail lights and took off the broken side marker lights near the front. I used it like this for several years.Alder-Lake-001.jpg
This was basically how I used it for many years although it was lacking a lot that would make it a better trailer and more useful. As I got ready to move in October of 2018, I put some flimsy sides on the trailer so that it would keep small boxes in the bed. I don't have any good pictures of that setup but here is the best view I could find.
Recently I decided to put some time and effort into the trailer to make it closer to my vision of what I want in a small trailer and to add a proper Datsun tailgate to it.
  • Replies 11
Nice.  I have very similar cheap sides on mine.  I just recently busted a leaf spring, so i ended up doing a conversion to an eye-to-eye type spring instead of a slipper spring.
I replaced the 2x4's on the side with 1x4's so that the side boards could be pushed outward a little on each side. This makes the deck width a total of four feet and 1/2 inch wide.
On the front of the floor I put a 1x4 down and slide the entire 4x8 foot plywood back. This makes the floor just over 8 feet long and the wood hanging out the back helps to protect the tail lights a little.
I used some free lumber to cut side boards to reinforce the walls and make the entire box more solid. Inside is painted brown and the outside I painted red all with free paint. Previously I put some stain on the bottom of the new 4x8 sheet to protect the wood from below. This is more of the look I had in mind. Now I can add some tiedown hooks or rings.
With the inside of the trailer just over 4x8 feet, you can stack plywood or sheetrock inside and it lays perfectly flat.
Because the trailer was designed to fold in half, there are some metal hinges that stick up in the center of the bed. These are just slightly less than 4 feet wide so they will damage 4x8 sheets of anything that is in the trailer. I decided to raise the floor of the bed to get around this and make the entire bed flat.
I just laid down some basic 1x4's to make a new wood floor.
I didn't want this fresh wood to look aged or get rotten by being out in the rain all winter. I put on some wood stain and then clear.
Here is the final product! I also put a second coat of red paint on the outside.
The last step to make this a proper Fake Datsun is to install a Datsun tailgate!
Even though 720 trucks are normally plentiful, right now I only see one in our local wrecking yards that is old enough to have the Datsun logo. I paid way too much for a dented 720 tailgate out of a wrecking yard... I'll bondo it up, sand, and then paint it red to match the trailer.
  • Like 3
  • 3 months later...
I've used the trailer for a few things and scratched the floor.
I picked up a 720 tailgate but it is not in good condition. At the time, it was the only 'DATSUN' tailgate I could find in Washington. It really is bent pretty bad so I am still on the lookout for a 720 truck tailgate in better condition...
Installed anyway just to use the trailer.
  • Like 5
  • Thanks 1
