Birddog223 Posted June 28, 2020 Report Share Posted June 28, 2020 Proud new owner of a strong running 620 with a L20b. 89,000 original miles. -gas gauge and temp gauge not working - turn signals not working Need some help on where to start please Quote Link to comment
datzenmike Posted June 28, 2020 Report Share Posted June 28, 2020 Does the oil light come on when you turn the ignition switch to ON. If YES then not the fuse. The Temperature and gas gauges are powered by a small voltage regulator set for around 7-8 volts. This prevents the gauges varying when the engine is off 12.65v, idling 13v or revved up to full 14.5 volts charging. The regulator is a set of points like in your distributor with a wire coiled around the arm which heats up and bends breaking the connection. It cools and bends back making the connection and repeats. The points can rarely become dirty and not make contact. Remove the gauge cluster from the dash and pull a folded strip if fine emery paper through them to clean and polish them. The voltage regulator in in the temperature gauge and powers the gas gauge also. If the red oil pressure warning light works then the fuse powering the turn signals is OK. Check your 4 way emergency lights. If they flash then find the two flasher units under the dash on the side of the steering column above the pedals and swap them. If the flashers now work and the 4 ways stop working then the original turn signal unit needs replacing. 1 1 Quote Link to comment
klam07 Posted June 28, 2020 Report Share Posted June 28, 2020 (edited) good luck! Edited June 29, 2020 by klam07 Quote Link to comment
Birddog223 Posted June 28, 2020 Author Report Share Posted June 28, 2020 No red oil pressure light. I’ll look through the fuses. In a Separate note, are there any fuse conversion To get away from the old round fuses? Maybe opening a can of worms but planning for future projects. Thanks for the knowledge. I’ll check the gauges shortly. Quote Link to comment
datzenmike Posted June 28, 2020 Report Share Posted June 28, 2020 To check fuses, turn the signal on and hold a quarter across the fuses one at a time. When it starts flashing you've found it. The 620 box is easy to remove and the wiring just unplugs. Take the fuses out (keep track) and wash vigorously with detergent and an old toothbrush, and rinse thoroughly. Now submerge overnight in a mixture of lemon juice and salt. In the morning use salt and a brush to polish, rinse and let dry. Quote Link to comment
EDM620 Posted June 29, 2020 Report Share Posted June 29, 2020 One thing to keep in the front of your mind: the majority of all electrical problems is the result of a bad ground. Check them before you get too far into diagnosing repairs! 1 Quote Link to comment
banzai510(hainz) Posted July 4, 2020 Report Share Posted July 4, 2020 (edited) Im late on this one put new fuses in and recheck my gas and temp gauge go out and I notice if I wiggle the fuses it comes back. There is a volt reg in back of the instrument panel bit it just a wrapped wire around a coil or some thing like that.unless it broke wire inside I don’t know how they go bad. I wiggle or put new fuses first Edited July 4, 2020 by banzai510(hainz) Quote Link to comment
Negative Ghostrider Posted July 5, 2020 Report Share Posted July 5, 2020 If all of your other external lights are working (brakes, corners, etc.) check your hazard switch. They are prone to failure and will prevent your turn signals from working. It could just be dirty contacts at the connections or it could be something internal. Pull the knob and see if the hazards work. If they don't you probably have a faulty hazard switch or bad connection. If they do, push it back in and try the turn signals again. If they still don't work try gently wiggling or twisting the knob to see if you get intermittent function. Quote Link to comment
homieelee Posted July 8, 2020 Report Share Posted July 8, 2020 On my '75 had the gas gauge & temp gauge not working. You can go to your gas tank, and look on top of it, there should be 2 wires. It connects to your fuel sending unit, unplug the one with the rubber grommet on it and ground it. Check if you see the gauge needle moves, easier if someone in the cab to confirm. For me, my actual fuel sender unit was busted as the needle moved but when connected back to the tank got nothing. temp gauge for me never rose up. I found out the PO completely gutted the thermostat, this made the coolant circulate 24/7 so the engine never warmed up. Probably not your issue, but just throwing ideas out there. Majority of the time when i wrench on the datsun, it ends up being correcting PO's crap they did to it. Quote Link to comment
datzenmike Posted July 8, 2020 Report Share Posted July 8, 2020 11 minutes ago, homieelee said: Majority of the time when i wrench on the datsun, it ends up being correcting PO's crap they did to it. AMEN to that!!! Quote Link to comment
Birddog223 Posted July 11, 2020 Author Report Share Posted July 11, 2020 Thanks All! I finally got a day off. I’ll start with the fuses and grounds. Start small and go big, from what I’ve read. You guys are super helpful Quote Link to comment
Birddog223 Posted July 11, 2020 Author Report Share Posted July 11, 2020 Anybody know how to remove these freggin knobs?!(wiper and lights) Quote Link to comment
Birddog223 Posted July 11, 2020 Author Report Share Posted July 11, 2020 Disregard.FYI the search button works in the site... Quote Link to comment
Birddog223 Posted July 12, 2020 Author Report Share Posted July 12, 2020 All lights working as well as gas gauge. Gutted the interior To have reupholstered. Any recommendations on getting the stock radio to work? Are they notorious to die? Tried to remove the dash but those fawkin screws under the front windshield...my God how are those supposed to come out? Next part is to stop the heater valve from leaking in the cab. Quote Link to comment
datzenmike Posted July 12, 2020 Report Share Posted July 12, 2020 It's 45 years old!!! Leave it in place to fool thieves, buy a new player and mount under seat and use remote 1 Quote Link to comment
Birddog223 Posted July 12, 2020 Author Report Share Posted July 12, 2020 No plans to take it out. Just thought it would be cool to work, especially the 8 track!! Quote Link to comment
Negative Ghostrider Posted July 19, 2020 Report Share Posted July 19, 2020 I'm leaving mine in the dash for theft deterrence. I am using a compact 4 channel marine-style amp under the dash and then just connecting my phone to it with a cable and using a Bluetooth controller on the steering wheel for volume/track/handsfree/etc. Pull the controller and stash the cable and nobody's the wiser. Putting generic parts express covers over the speakers to make them look cheap as well. Quote Link to comment
