Chowhall Posted June 14, 2020 Report Share Posted June 14, 2020 Im starting a rebuild of a 71 521 with a L20B engine and was wondering where can I get a hardware kit to replace all the hardware. Some of the bolt were mix and match. Quote Link to comment
DanielC Posted June 14, 2020 Report Share Posted June 14, 2020 (edited) You can reuse the head bolts, main cap bolts, crankshaft and camshaft bolts, so I am going to suggest you are looking for the bolts you can reach on the outside of the engine. If nobody suggests a kit that is available, we are talking about a 40 year old engine here, I would go to a junkyard with older Nissan cars and trucks, and harvest bolts. Most common bolt sizes you need are M6-1.0, M8-1.25, and M10-1.5. You need those size taps to chase the threads in all the threaded holes in the engine parts when you put the engine back together Edited June 14, 2020 by DanielC Quote Link to comment
datzenmike Posted June 14, 2020 Report Share Posted June 14, 2020 In addition the Nissan ones are higher quality and grade. Quote Link to comment
Stoffregen Motorsports Posted June 15, 2020 Report Share Posted June 15, 2020 Yes, Nissan bolts are a much better quality than hardware store junk. Take some time to clean the bolts, nuts, washers, with a brass brush and a drill, some chemicals and elbow grease, and the results will amaze you. The engine will have a much better look with slightly tarnished OEM bolts than with anything aftermarket. Yes, I am even calling out you stainless bolt guys. Stainless is for boats. Quote Link to comment
DanielC Posted June 15, 2020 Report Share Posted June 15, 2020 Very basic metallurgy. Higher percentages of carbon in steel make it stronger. Carbon make also makes steel rust. The cheapest way to make "stainless steel" is to reduce the amount of carbon in the steel, and that reduces the amount of chromium you have to add to the alloy to reduce rusting. 1 Quote Link to comment
banzai510(hainz) Posted June 15, 2020 Report Share Posted June 15, 2020 Chowhall all the Datsun L motors are metric key is write this down when you get the infor m6x whatever all the body and chassis on a 521 is SAE / brake lines ect is SAE so when come to a 521 order 521 specific stuff hydraic part ect………. radiator bolts 5/16x24 example. zcardepot.com has bolt kits for the motors but a good hardwares store will have these also. I always like the Nissan stuff myself and just get them from motors that go to the dump over the years. I can look at a bolt and pretty sure figure out where it goes. Im not into allen bolts even if they are the shiny chome looking ones. Quote Link to comment
datzenmike Posted June 15, 2020 Report Share Posted June 15, 2020 SS is weaker? All I can say is I have swapped in SS in for regular bolts and twisted the tops off. Now I wasn't being careful and using a torque wrench but they definitely break easier. Quote Link to comment
grannyknot Posted June 15, 2020 Report Share Posted June 15, 2020 5 hours ago, Stoffregen Motorsports said: Yes, Nissan bolts are a much better quality than hardware store junk. Take some time to clean the bolts, nuts, washers, with a brass brush and a drill, some chemicals and elbow grease, and the results will amaze you. The engine will have a much better look with slightly tarnished OEM bolts than with anything aftermarket. Yes, I am even calling out you stainless bolt guys. Stainless is for boats. Besides the SS will corrode where it is touching the iron or aluminum anyway. Better yet, take all your bolts and hardware off and ship them to the platers and have them all come back like new. 1 Quote Link to comment
Stoffregen Motorsports Posted June 15, 2020 Report Share Posted June 15, 2020 Yes, new plating is the best option. I have three 5gallon buckets of hardware ready to go to the platers. Nothing looks as good. Not even stainless. Quote Link to comment
