Diesel Dentures Posted September 1, 2020 Author Report Share Posted September 1, 2020 What do y’all think about the condition of the bed mount bushings? 1 Quote Link to comment
wayno Posted September 1, 2020 Report Share Posted September 1, 2020 (edited) That is what they all look like, I just re-use them, I don't want to put a large fortune into my builds, a small fortune is enough for me, I just wire wheel everything. OK, maybe your talking about the rubber piece, I have parted out so many 521/720s over the years that I have a 5 gallon bucket of rubber pieces, Jagman has a good idea below, also my local hardware store has scrap rubber pieces they sell at a discount in several different thicknesses. Edited September 1, 2020 by wayno 3 Quote Link to comment
jagman Posted September 1, 2020 Report Share Posted September 1, 2020 I have used tire sidewall rubber for bushings like these. all you need is a drill press and a hole saw (preferable if it is for metal) in the right diameter for the outside of the bushing. If the center hole needs enlargement (nearly always) use a small diameter hole saw or high speed drill bit but clamp the piece very securely. The only exception to this method was when the shop I was working in decided to replace the " comfort " floor mat in front of the mill drill and I bagged that for making body mount bushings for my chrysler. It was tougher to cut than the tire rubber. 2 Quote Link to comment
Diesel Dentures Posted September 2, 2020 Author Report Share Posted September 2, 2020 12 hours ago, wayno said: That is what they all look like, I just re-use them, I don't want to put a large fortune into my builds, a small fortune is enough for me, I just wire wheel everything. OK, maybe your talking about the rubber piece, I have parted out so many 521/720s over the years that I have a 5 gallon bucket of rubber pieces, Jagman has a good idea below, also my local hardware store has scrap rubber pieces they sell at a discount in several different thicknesses. Man, auto parts stores or the alike on the western side seem to have all those cool little extras laying around or somewhere in stock for people with hobbies. They seem few and far between over here. There is a very useful “nuts&bolts” store up the street and the gentleman that runs it could tell you the dimensions of a bolt/screw on the ground from a mile away. Every time I go in there I tell him to never shut down, cause I’d be screwed(pun intended). Do you happen to know the original size of the 720 bushings? Maybe I could find something close to the original thickness. 2 Quote Link to comment
Diesel Dentures Posted September 2, 2020 Author Report Share Posted September 2, 2020 11 hours ago, jagman said: I have used tire sidewall rubber for bushings like these. all you need is a drill press and a hole saw (preferable if it is for metal) in the right diameter for the outside of the bushing. If the center hole needs enlargement (nearly always) use a small diameter hole saw or high speed drill bit but clamp the piece very securely. The only exception to this method was when the shop I was working in decided to replace the " comfort " floor mat in front of the mill drill and I bagged that for making body mount bushings for my chrysler. It was tougher to cut than the tire rubber. This is helpful I’ll have to see what I can scrounge up. 1 Quote Link to comment
Diesel Dentures Posted September 20, 2020 Author Report Share Posted September 20, 2020 Hey people! Sorry I’ve been MIA. The machine shop I’ve taken some parts to is taking longer than expected. I’ve had my hands on a 3 wheeler rebuild in the meantime. I’ll add more pics and an update soon! 1 Quote Link to comment
Diesel Dentures Posted September 25, 2020 Author Report Share Posted September 25, 2020 here’s the new bushings I got for my leaf springs! 1 Quote Link to comment
Diesel Dentures Posted September 25, 2020 Author Report Share Posted September 25, 2020 Finally got the rear suspension sandblasted, primer and painted( leaf springs, shackles, etc). along with the rear struts from KYB. The suspension is nice and tight now. It’s like a night and day difference. 1 Quote Link to comment
Diesel Dentures Posted September 25, 2020 Author Report Share Posted September 25, 2020 And I also painted the gas tank. Here’s a side by side for y’all! 1 Quote Link to comment
Diesel Dentures Posted October 25, 2020 Author Report Share Posted October 25, 2020 This weekend I decided to re-line the bed since the first time i did it, the sun decided to let the primer soak up a lot more than I expected. So here’s a 2nd and fresh coat for the ol girl Quote Link to comment
Diesel Dentures Posted October 25, 2020 Author Report Share Posted October 25, 2020 I also touched up under the bed where some surface rust was by sanding and primer and some flat back over top of it. Quote Link to comment
Diesel Dentures Posted October 25, 2020 Author Report Share Posted October 25, 2020 Other than those two updates. I had gotten it out of the garage and decided to go for a spin around the neighborhood before the bed was put on. Well I have two things to say.... it ran like a beauty , and always make sure your lugnuts are tightened. I say this because on my “spin” around the neighborhood my driver side tire came off and hit a car in a driveway. Luckily no damage was done to me the truck or that lady’s car. She was very polite about everything . The reason the tire came off to my assumption is that I had out the lug nuts on while the truck was in the air and must’ve forgotten. I hadn’t worked on that side of the truck in some time and didn’t go double check myself before the drive. So idiot move on my part. The only damage to the truck was a lower control arm bolt connecting to the ball joint that runs through the torsion bar, was sheared but that’s an easy fix. Keep on truckin 1 Quote Link to comment
wayno Posted October 26, 2020 Report Share Posted October 26, 2020 Do you mean one of the 2 bolts that go thru the tension rod up thru the ball joints with a nut on top holding both of them to the lower control arm? 1 1 Quote Link to comment
Diesel Dentures Posted November 13, 2020 Author Report Share Posted November 13, 2020 Yes that’s exactly the one I’m talking about. Also sorry for the slow updates guys/gals. My next big purchase is tires and I’m trying to decide if I want to use the 14in factory wheels that I was given, or move onto a bigger size wheel and along with that comes finding a design that fits the truck. I’m not a huge fan of the xterra look or some of the newer style. In my opinion it clashes and throws off the look. So hopefully I find something that fits the trucks style that I’m leaning toward. If not, I do like the look of the factory wheels. It’s just easier to find 15 inch rather than 14. 1 Quote Link to comment
bottomwatcher Posted November 14, 2020 Report Share Posted November 14, 2020 I don't even think extara would fit. Toyota, chevy, isuzu,whatever with the 6 on 5.5 is what you are looking for. I would love to find a set of Toyota turbines! 1 Quote Link to comment
Diesel Dentures Posted April 11, 2021 Author Report Share Posted April 11, 2021 Hey guys/girls ! I’m in the motion of turning wrenches again now that the weather is in my favor ! I was hoping to gather some information on tire fitment for 14” wheels. I know my last post was relatable to this but in a way I’m trying to keep the stock-ish appeal with minor flair. My goal is to try and hide as much of the inside fender well as possible. To put it easy I’d like to have a 14in tire with some beefy tread on the wheel. I’ve attached a picture of what I’m imagining (just without the lift) keyboard check software 1 Quote Link to comment
Charlie69 Posted April 11, 2021 Report Share Posted April 11, 2021 Your taillights in the picture are vetical in the bed the taillights. The ones I have are horizontal under the bed taillights. 1 Quote Link to comment
Diesel Dentures Posted April 11, 2021 Author Report Share Posted April 11, 2021 Yes my taillights are horizontal under the bed. The picture is for reference 1 Quote Link to comment
Diesel Dentures Posted April 29, 2021 Author Report Share Posted April 29, 2021 (edited) Well rats, I got the wheels and tires I was looking for and I couldn’t be happier with the outcome! Edited April 29, 2021 by Diesel Dentures 1 Quote Link to comment
Diesel Dentures Posted May 6, 2021 Author Report Share Posted May 6, 2021 Did some work today! Along with some new to me bump stops from good ol wayno Quote Link to comment
Diesel Dentures Posted May 6, 2021 Author Report Share Posted May 6, 2021 Sanded down the tension rods and added some paint to them along with brushin up my old housings for the taillights 1 Quote Link to comment
Diesel Dentures Posted May 6, 2021 Author Report Share Posted May 6, 2021 The tension rods I didn’t snap a picture of after the paint but if you squint you can see them in the pictures above 1 Quote Link to comment
Charlie69 Posted May 6, 2021 Report Share Posted May 6, 2021 Those housing look good, are you still wanting another set? 1 Quote Link to comment
Diesel Dentures Posted May 7, 2021 Author Report Share Posted May 7, 2021 I actually was able to make the ones I had work out. The weaker spots that had rust and where 2 mounting bolts snapped off inside the the threads were actually fixed with some braising and I had them sandblasted. So now they are sturdy. I need to find a good replacement for the gasket inside of the housing as the original was dry rotted and crumbling 1 Quote Link to comment
Charlie69 Posted May 7, 2021 Report Share Posted May 7, 2021 Get with Jake Makes and he might be able to make some. Jake Makes profile 1 Quote Link to comment
