banzai510(hainz) Posted June 15, 2020 Report Share Posted June 15, 2020 (edited) 120 across is good. this is a simple fix Edited June 15, 2020 by banzai510(hainz) Quote Link to comment
Sonreir Posted June 15, 2020 Author Report Share Posted June 15, 2020 Yeah... I figure it's gotta be something with the fueling at this point. I've already ruled out spark and compression... Quote Link to comment
banzai510(hainz) Posted June 15, 2020 Report Share Posted June 15, 2020 what is the ohm value of that coil????? if its 3 ohms andyou have the ballast (say 1.6 ohms(is series your spark strength is actaully lower . 3+ 1.6 =4.6OHMS 12VOLTS/4.6OHMS=2.6AMPS. Maybe its fine but its a possibitity Quote Link to comment
Sonreir Posted June 15, 2020 Author Report Share Posted June 15, 2020 3.3Ω for the primary on the coil. Quote Link to comment
datzenmike Posted June 15, 2020 Report Share Posted June 15, 2020 Jumper around the ballast resistor and try it. 3 ohms is what the stock coil 1.5 and the ballast 1.5 add up to. Quote Link to comment
Stoffregen Motorsports Posted June 15, 2020 Report Share Posted June 15, 2020 3 hours ago, banzai510(hainz) said: do a Mexican tune p. Rev the motor then put a rag over the carb and maybe it will suck the dirt thru. Or maybe pull the dirt out of the rag into the carb sure your not running on 3 cylinders? Believe it or not, this does work. Careful though, I've heard horror stories of people getting their hands torn open from the suction. Quote Link to comment
banzai510(hainz) Posted June 15, 2020 Report Share Posted June 15, 2020 put the stock coil back in with the orginal ballast , try that Quote Link to comment
Sonreir Posted June 15, 2020 Author Report Share Posted June 15, 2020 2 minutes ago, banzai510(hainz) said: put the stock coil back in with the orginal ballast , try that I was having similar trouble before I swapped, but I'll give it a go and see what happens. Quote Link to comment
banzai510(hainz) Posted June 15, 2020 Report Share Posted June 15, 2020 (edited) your swapping to many things at once I personally didn't think your distributor/coil was bad in the first place more out of time than anything since the dist was clocked all to one side to get 10degs. Which means as I satated earkier a tooth off or mistached dist to pedestal set up. I good distributor set up once running the dist timming can be run down to zero and up to 25btdsc just by the timming slot when you turn the dist left and right. so when you said its cranked all to one side to get 10BTDC or maybe the 8mm bolt under neath the plate could be adjusted more to get aa btter slot adv once you moved it. Edited June 15, 2020 by banzai510(hainz) Quote Link to comment
Sonreir Posted June 15, 2020 Author Report Share Posted June 15, 2020 Timing and spark appear to be OK with the new electronic distributor. I'm currently set at 14° BTDC with plenty of slack to go in either direction. Quote Link to comment
banzai510(hainz) Posted June 15, 2020 Report Share Posted June 15, 2020 (edited) try run it at 7 then 10 12 14. really adv it right before it pings what someone told me once just make sure that 2nd bareel the spring is on there to keep it closed. i seen where the spring fall off the holder and prematurely opens and bogs the motor down by letting to much air in thru the 2nd barrel side Edited June 15, 2020 by banzai510(hainz) Quote Link to comment
