510revisited Posted June 7, 2020 Report Share Posted June 7, 2020 I need the hose that comes off the block breather pipe. Its around 7/8 diameter. Cant seem to find any at the local auto stores, or online. Any and all is appreciated Quote Link to comment
datzenmike Posted June 7, 2020 Report Share Posted June 7, 2020 The block vent end is larger diameter than the PCV end, figures doesn't it??? Plus it's formed into a curled shape. I did get an engine once that had a broken block vent pipe with a piece of garden hose stuck in the end going to the PCV. Try finding two hoses that fit each end and slip one into the other. You could always use a hose clamp. Hoses should be gasoline resistant. Welcome to classic car ownership where sometimes you have to make your own parts to stay on the road. You could try a want add... https://ratsun.net/classifieds/category/9-datsun-parts/ ... for a used one. L16/18 are the same. L20B are different. Quote Link to comment
510revisited Posted June 7, 2020 Author Report Share Posted June 7, 2020 Found this. Gotta confirm its 7/8 id. https://puredieselpower.com/products/oil-drain-hose-for-turbo-7-8-sold-by-the-foot.html#/product/17680 Quote Link to comment
510revisited Posted June 29, 2020 Author Report Share Posted June 29, 2020 So, i did a thing. Worst part was having enough patience to deal with ups.. this Plus a foot of this at oreillys (cheaper than $35) AND THIS Make this... oh, and this Hopefully this will help others with the same issue.. 2 Quote Link to comment
datzenmike Posted June 29, 2020 Report Share Posted June 29, 2020 You're a goddamned genius! 1 Quote Link to comment
510revisited Posted June 29, 2020 Author Report Share Posted June 29, 2020 2 hours ago, datzenmike said: You're a goddamned genius! Ive been called worse. Better i suppose as well.. 1 Quote Link to comment
