Spindle compatibility help
Zeek90
Hello everyone. Starting to work on my 77 b210 more now. I have a  few questions to ask. Now im thinking of buying a set of stock 510 strut assemblies that were coilover converted, with brake calipers included. Now i hear i can use 510 coilovers on my b210, so if i do make that purchase will all that work on my b210 an fit perfect? an just run the 510 brakes? Or if my b210s spindles are the same as the 510s spindles, could i just attach my b210 rotor an calipers to the 510 strut assembly? Thanks
  • Replies 1
The B--210 will have better brakes and the wheel bearings are larger than the 510. Switching to 510 struts is a step backwards. Both are 2" strut tube so put the coil overs from the 510 on your B-210 struts and throw the 510 ones away. Or sell them. Better yet get coil overs for your B-210 and forget the 510 struts.
