Aems Bunny Posted June 3, 2020 Report Share Posted June 3, 2020 I have a 82 Datsun Maxima diesel and I’m new to the Datsun scene, I need helping figuring out if I can do a 5 lug conversion on it and if I can use a s13-s14 5lug conversion kit since I can pretty much swap the s13 or s14 coilovers onto it or if there is a specific kit that I need for it. Any help is appreciated and thank you for your time. Quote Link to comment
datzenmike Posted June 4, 2020 Report Share Posted June 4, 2020 The Maxima has a strut with integral spindle. The S13/13 are separate and the hubs are vastly different with different bearings so they won't interchange. If you want a 5 bolt strut the 300zx turbo had them. You'll need the calipers with them as I doubt swapping the 5 bolt hub onto the maxima will fit. I guess this is because you want to run to-days 19" rims??? Why not look for a set of factory 810 or Maxima aluminum mags that look correct? 280zx were also nice. Quote Link to comment
Aems Bunny Posted June 5, 2020 Author Report Share Posted June 5, 2020 On 6/3/2020 at 8:14 PM, datzenmike said: The Maxima has a strut with integral spindle. The S13/13 are separate and the hubs are vastly different with different bearings so they won't interchange. If you want a 5 bolt strut the 300zx turbo had them. You'll need the calipers with them as I doubt swapping the 5 bolt hub onto the maxima will fit. I guess this is because you want to run to-days 19" rims??? Why not look for a set of factory 810 or Maxima aluminum mags that look correct? 280zx were also nice. It’s all apart of the learning curve and process for me. I’ll try the z32 strut and see if it works if not then back to the drawing board. And thanks for the advice. I’m just trying to make it different Quote Link to comment
datzenmike Posted June 5, 2020 Report Share Posted June 5, 2020 You'll need 5 bolt rims and what about the rear??? Then the 300zx calipers will probably need a larger master, then... I believe in not fixing something that isn't broken. Quote Link to comment
DARIN 510 Posted June 5, 2020 Report Share Posted June 5, 2020 Z32 doesn’t use struts either. For the rear I guess you can do the same as the 510 guys? I don’t trust it. I agree with datzenmike or maybe upgrades that are within reason. Like not reinventing the wheel. Quote Link to comment
slowlearner Posted June 7, 2020 Report Share Posted June 7, 2020 I just looked up the Datsun Maxima on google. So interesting. We got the 810 Bluebird here, which looks like the same car but with a shorter boot and bonnet and only the L20 and a solid rear axle. I know the JDM models included Z18DET and FJ20DET motors with IRS. I had no idea you guys got them as a 6cyl, let alone the L28 diesel. We only got that diesel motor in Patrols. It'd be fun to throw a turbo on that motor. It'd be a great sleeper! Quote Link to comment
Aems Bunny Posted June 7, 2020 Author Report Share Posted June 7, 2020 3 hours ago, slowlearner said: I just looked up the Datsun Maxima on google. So interesting. We got the 810 Bluebird here, which looks like the same car but with a shorter boot and bonnet and only the L20 and a solid rear axle. I know the JDM models included Z18DET and FJ20DET motors with IRS. I had no idea you guys got them as a 6cyl, let alone the L28 diesel. We only got that diesel motor in Patrols. It'd be fun to throw a turbo on that motor. It'd be a great sleeper! My brother wants to throw an RB in it, idk which one he meant though. Quote Link to comment
slowlearner Posted June 7, 2020 Report Share Posted June 7, 2020 (edited) If the diesel is healthy.. and heck, those motors are pretty stout, an ebay turbo and fuel pump work would be much cheaper and easier. Could even be that a petrol 280zx turbo manifold might fit right up. A lot of other things about the L series motors are similar. Don't quote me on that though. @datzenmike would probably know. Edited June 7, 2020 by slowlearner Quote Link to comment
Aems Bunny Posted June 19, 2020 Author Report Share Posted June 19, 2020 So would the 280zx turbo manifold be able to mount up or would I need to do a lot more fabrication? Quote Link to comment
datzenmike Posted June 19, 2020 Report Share Posted June 19, 2020 One of the 280zx (non turbo) exhaust manifolds was used on the L24 in the Maxima. By extension the turbo should fit also. LD28? They look the same but .... ? LD28Ts were sold Australia/New Zealand but unknown if they used the zx manifold. Quote Link to comment
thisismatt Posted June 19, 2020 Report Share Posted June 19, 2020 Whatever you decide, the crank in that motor is worth more than the car. It's a forged crank and can be used in the regular L24/L26/L28 motors to make a stroker. Worth $1000-1500 by itself. Quote Link to comment
Aems Bunny Posted June 19, 2020 Author Report Share Posted June 19, 2020 Good to know I’ll keep it in mind Quote Link to comment
ArchetypeDatsun Posted June 24, 2020 Report Share Posted June 24, 2020 The VO7 block is also a good use to do a 3.5 stroker with custom crank but your talking 10s of thousands you would be upwards of $20k build by rebello. Run the diesel as is and enjoy it. Don't see too many people keep the LD28. I do believe I've seen someone on the FB 810/910 owners page do a 5 lug conversion. Quote Link to comment
Aems Bunny Posted June 24, 2020 Author Report Share Posted June 24, 2020 Hm so what internals can I use to make it into a stroker ? Quote Link to comment
