rallytwo Posted May 23, 2020 Report Share Posted May 23, 2020 any help or direction for finding 1969 datsun 510 water pump thanks , Rob Quote Link to comment
datzenmike Posted May 23, 2020 Report Share Posted May 23, 2020 Rock Auto, NAPA, Lordco, Bumper to Bumper, Summit, O'Relieghs.... any auto parts store. Quote Link to comment
Draker Posted May 23, 2020 Report Share Posted May 23, 2020 39 minutes ago, rallytwo said: any help or direction for finding 1969 datsun 510 water pump thanks , Rob My 69 510 had a drum clutch type water pump. If yours is original, yours might be also. Bad news though, you'll never find those parts. If you have that type in your car, I'd just buy a pump from rockauto. And you'll need a new fan to go with it. Aisin is the OEM for toyota water pumps, and they make pumps for the L motor. It's a quality pump with a cast impeller. If you have a viscus clutch or no clutch at all, you'll be able to find a replacement pretty easy and then you can just reuse your existing fan. If you have the drum clutch type and you'd like to keep it, you can. There are a few companies that rebuild water pumps, but it won't be cheap. Quote Link to comment
MikeRL411 Posted May 23, 2020 Report Share Posted May 23, 2020 So, post this in the 510 section, not the 410 / 411 section. Quote Link to comment
banzai510(hainz) Posted May 25, 2020 Report Share Posted May 25, 2020 Zcardepot has the Japan made one 551 is the part number anything under$ 30 is most likely Chinese GMB is ok and a run them before but the cast vanes are better(cavatation)on front cover. run 50/50 mix !!!!!! never garden hose water. Swap out every 3 years . Quote Link to comment
