oil pump upgrade L or Z series
EDM620
Following up on a discussion re: increased volume/pressure for an oil pump on my Z24 build, I have confirmed with Melling the following:
M90 pump has a lower volume output, while the M111 & M152 pumps flow the same rate of 2 gallons/min @ 491 RPM. The M152 pump however has a 10psi higher bypass setting. Somewhere on the web I'd read that the M152 had a higher flow of 2.25 gal/min however Melling states that is incorrect.
  • Replies 1
If you want cheaper there are lots of KA  Hardbodys in the wrecking yards. They may be used but being an oil pump they didn't lack for lubrication. I grab them when I find them. Have never paid for one. One time the guy said $25 and I said can I sue you if my engine seizes up because of it? He told me to get going. Have always run the KA pumps on all my L20Bs and my Z24.
