Curious what L series or series engine is this?
  • Replies 3
That's a '75 or newer 620 so it came with an L20B.
Lock at the top of the block where it meets the head behind the oil dip stick. There's a flat boss with the engine size stamped on it.
Look at the top of the cam chain cover, just below the cylinder head.  In the bottom right of this picture see the two bolt heads about a inch apart, below and right of the smaller bolt with a wire.  If it has the two bolts in this location, it is a L-20-B engine.  Only one bolt here, it is a L-16 or a L-18
