zquinn19 Posted May 13, 2020 Report Share Posted May 13, 2020 Hello all My Boss is restoring a 1983 720 Deluxe at the body shop I work at. We cannot seem to find the correct rear window seal anywhere and I'm hoping someone can point me in the right direction. We've ordered 2 so far and both are not wide enough or tall enough to fit into the window frame. I've been searching the internet but everything seems to have the same look as what we already have. If anyone can help me out it would be greatly appreciated. 1 Quote Link to comment
datzenmike Posted May 13, 2020 Report Share Posted May 13, 2020 Is it a Regular or King Cab? 'cause they look larger on the KC. 1 1 Quote Link to comment
zquinn19 Posted May 13, 2020 Author Report Share Posted May 13, 2020 It's a king Cab 1 Quote Link to comment
Draker Posted May 13, 2020 Report Share Posted May 13, 2020 route 66 on ebay used to have 720 seals. Not sure if they are the correct size, but may be worth looking at. 1 Quote Link to comment
Chopper Jim Posted May 13, 2020 Report Share Posted May 13, 2020 1983 Nissan K C weatherstrip rear window part #79710-12W00. It has been discontinued. Could still be some out there. You have 2 that are too short & narrow, you may have to get creative & cut them up & glue them together. Some very good rubber cement. We have had to do that on a few chop tops. Chopper Jim 1 Quote Link to comment
jagman Posted May 13, 2020 Report Share Posted May 13, 2020 You can check with Steel Rubber Products to see if they have anything that might fit. I have had some luck with their extrusions for some oddball stuff i've worked on. 1 Quote Link to comment
