Suki68 Posted May 13, 2020 Report Share Posted May 13, 2020 I’m changing out my crank seal. I’m trying to get my crank bolt loosened on my J13 and cannot get any leverage. The pulley turns. Any ideas on what to do? Quote Link to comment
wayno Posted May 13, 2020 Report Share Posted May 13, 2020 (edited) Block the tires, put it in gear, impact is better. I have heard about a way of using the starter and a breaker bar but don't know the details. I assumed the engine was in the vehicle, if not in the vehicle get a long piece of flat bar and drill 2 holes in it to mount on the flywheel so one end hangs out and will hit on the ground, that will stop the engine from turning. Edited May 13, 2020 by wayno 1 Quote Link to comment
datzenmike Posted May 13, 2020 Report Share Posted May 13, 2020 Put in 4th gear and set the brakes too. 1 Quote Link to comment
john510 Posted May 13, 2020 Report Share Posted May 13, 2020 The breaker bar and starter trick or an electric impact gun.I did it with the starter and it only took one quick turn of the key. 2 Quote Link to comment
Suki68 Posted May 13, 2020 Author Report Share Posted May 13, 2020 Thanks guys! Once again, helpful as ever 2 Quote Link to comment
Draker Posted May 13, 2020 Report Share Posted May 13, 2020 I've done it before. Just make sure the engine spins clockwise if using the starter trick, otherwise you'll be taking a trip to the machine shop. 🙂 1 Quote Link to comment
