Nissan PulSAR N14 Dust Covers
Hello
Today i mailed Nissan in Portugal, in order to buy new Ball Joint and tie end rods dust covers boots, to my Nissan N14, and i was suprised that dont sell this parts sells the all lower arm suspension and the tie end rod.
If you know let me know where i can find, the dust covers with good quality and if is possible assembly them
Many thanks on advance
Luis
Link to post
  • Replies 2
You may have to rely on after market split boots for this.  You cut the existing boots off, slip the split boots on, apply cement or sealant to the flanges and tighten up the bolts if the boots use them.  Sure beats removing and replacing steering components to get to thee boots.  No realignment required as a bonus.   have no idea where in Portugal or Europe you can find these boots.  If you have access to a parts supplier catalog, good luck.
Link to post
Hello
Can advice me a  C  lower ball joint PRESS KIT to Nissan Pulsar N14 diameter 39,2 mm ball joint
Im afraid to buy one and its bigger for the job
 Ball Joint Servicing Kit BALL JOINT SERVICE TOOL SET WITH 4X4 ADAPTOR
 2-3/4" x 3" 2-1/4" x 2-1/2" / 1-3/4" x 2"  confused measures
Thanks
Luis
Link to post
