AlexDeLarge Posted May 10, 2020 Report Share Posted May 10, 2020 Need to replace front right wheel cylinder on my '74 620 and was hoping someone could tell me the correct way to remove the old one. I have the brake hose loosened from the Y adapter coming off the wheel cylinder and I have the small nut on the other end on the hard line loosened. Seems to me if I remove that hose I'm going to dump brake fluid everywhere. I can't get a wrench to that nut holding the wheel cylinder in because the Y adapter and hose is in the way. Only way I see to do it is remove hose, then remove y adapter, then wheel cylinder? Sorry, my first time messing with this. I have everything else removed as I am replacing springs and shoes also. Thanks Quote Link to comment
AlexDeLarge Posted May 10, 2020 Author Report Share Posted May 10, 2020 Never mind, I figured it out. 1 Quote Link to comment
