vicdat Posted May 15, 2020 Report Share Posted May 15, 2020 Yeah...I was lucky....many years later my ball joint broke on my '79 King Cab and i had to tow that one off the Riverside Freeway.....hahajaha Quote Link to comment
mklotz70 Posted May 15, 2020 Report Share Posted May 15, 2020 1 hour ago, vicdat said: FYI - On my old 521 back in the day (late 70's), one of my kingpins broke on the Long Beach Freeway...I muscled if off the road. It turned-out that the Zirk fitting for it was never drilled-out all the way from the factory and it never got any grease..... Vicdat That could have been the case, but I'd be willing to bet that the actual problem was that the bushings were not oriented correctly to line up with the holes. In effect, the exact same issue. I know it's a technicality, but for anyone doing their own kingpin rebuilds, they need to line the holes up. I wonder if there's a chance that the bushing got dry and stuck to the pin.....and then rotated in the casting...? I'm glad you posted that Vicdat.....it's something I've never come across and never thought about happening. If I ever do any more rebuild vids about kingpins, I'll bring that up for owners to look for. :) Quote Link to comment
banzai510(hainz) Posted May 17, 2020 Author Report Share Posted May 17, 2020 Been cleaning up the fender area drilling out the lamp bucket screws all 4 bad got 2 brake lines a 51 & 40 in 3/8x24. 3-16 line from napa pass side rear red lens broke of but housing still there my pass side marker looks ok but is rotted out and bulb housing broke right there I have 510 ones but the spacing and lens is slightly different was wondering if anybody can clone the 521/510 ect.. housings using a 3D printer and use the Ford/GM 194 bulbs which has the 2 wires.as the lamps seem to rot out in the metal housing And can’t get the light out. I had been hacksawing the bulb bucket out Of the Rotted Datsun housings then replaced with a new bulb socket and JB welded to the housing that rotted but the bucket is new so one can replace the bulb but the GM 194 sockets are plastic and won’t rust. my housing is like totally rotted. if any body knows a link for 521 marker light please post. I need a red lens or I will just use a rear 510 and drill into the fender on one side and make it work as the 510 one is slightly longer than the 521 1 Quote Link to comment
banzai510(hainz) Posted May 19, 2020 Author Report Share Posted May 19, 2020 UPDATE swapped out the pass side Kingpins as hey were worn. EZ did the driver side and find out the lower Fulcrum pin is stuck in the spindal housing. I need to Sawzall pin to get that out. Then find out the upper A arm 2 links that bolt to the upper spindal and to the body of the truckwhere, the bushing End caps up are wiggling , So now these are shot. FUCK 521s are just a PAIN compared to a simple 510. I wished I got a 78/79 620 kingcab thinking about it now but in the day Im down to my last 521 Fulcrum pin and upper links to body. Anybody have anyspares????? I got 2 recs out now see who has what(more local) also the bleed screw is stuck in the clyninder block that it screw into,and remove both together and trying to get the bleed screw out is not working with Vicegrips(BPBlaster/heat) I ordered 2 new Japan wheels cylinders from ebay and it has the all the pieces unlike the Rockauto stuff so Ill just use the block with the cruchwashers with the new bleed screw and save the cylinder for later as I don't want to attempt to brake the soft line hooked up the the wheel cylinder 1 Quote Link to comment
DanielC Posted May 19, 2020 Report Share Posted May 19, 2020 521 side marker lights share a lot of common parts with other Datsuns, even for years after the 521 was no longer made. About the only part on the marker light assembly that is unique to a 521 is the rubber base. The wires need to be longer on the front 521 side marker lights because the connector for the light is inside the engine compartment. If you have a lamp that is stuck in the housing on a 521 or any other Datsun with this style of side marker, break the bulb, and then with a small punch, or a pick hammer, break the ceramic out of the bulb base that was used to glue the bulb glass to the bulb base. Then crush, or squeeze the metal base in from two points 180 degrees across from each other. You may be able to do this with a pair of needle nose pliers. After squeezing the two sides of the lamp base together, the overall diameter of the lamp base will shrink, and usually can then be easily removed from the marker light socket. 1 Quote Link to comment
banzai510(hainz) Posted May 19, 2020 Author Report Share Posted May 19, 2020 I have 510 housings and lense but they are slightly longer and don't match up to the holes. The housings are almost new looking. I might just drill a new hole and put a cli[p to hold the sheelmetal screw. But if I find a 521 set would be good also. I replied back to our PM. Yes I have done that before with the bulbs 1 Quote Link to comment
Icehouse Posted May 26, 2020 Report Share Posted May 26, 2020 Some update pics of the truck. 3 Quote Link to comment
Draker Posted May 26, 2020 Report Share Posted May 26, 2020 Impressive work! Who knocked that dent out? 1 Quote Link to comment
banzai510(hainz) Posted May 27, 2020 Author Report Share Posted May 27, 2020 (edited) A 510 guy that lives near me. Hes my local help when I need him. I help him out on 510 parts. So he helps if I’m hurting. He is rarely on here.Name is Derick. New kingpins spindals and upper links on driver side .new brake line to rear that was rusted. just got the brakes adjusted. be able to roll pretty soon Edited May 27, 2020 by banzai510(hainz) 5 Quote Link to comment
Draker Posted May 27, 2020 Report Share Posted May 27, 2020 Crazy.. he did a great job! Glad to see this thing will be back in the road, and in short order. 1 Quote Link to comment
Snowball Posted May 27, 2020 Report Share Posted May 27, 2020 Not to hijack your thread but does anyone know where to get those y blocks for the rear drum? Mine just broke and I can't find on rock, thanks in advance. 1 Quote Link to comment
banzai510(hainz) Posted May 27, 2020 Author Report Share Posted May 27, 2020 (edited) ebay has these and comes with Y blocks. try to get the ones already in US as most come from Thailand. the fronts sold thru Rockauto don't come with the bleed blocks. You use the old one. it comes with new set of crush washers sAYS FOR 521 https://www.ebay.com/itm/FIT-NISSAN-DATSUN-520-521-1300-TRUCK-PICKUP-REAR-WHEEL-BRAKE-CYLINDER-NEW-65-72/114214984222?fits=Make%3ADatsun&hash=item1a97be5a1e:g:wJIAAOSwGSZesuVe Edited May 27, 2020 by banzai510(hainz) 1 Quote Link to comment
Snowball Posted May 27, 2020 Report Share Posted May 27, 2020 Just to confirm by going off the car parts website the y bleed housing part number is 41130-14800 or 41130-14810? I called my local Nissan dealer and found something under one of those number that could be shipped from Japan, but I want to confirm that is the correct number if anyone can help that would be great. Quote Link to comment
banzai510(hainz) Posted May 27, 2020 Author Report Share Posted May 27, 2020 from Japan,????? then find out you got metric 620 one. Crap just get new cylinders anyways what I posted, which it needs it and get it from Calif. Quote Link to comment
Snowball Posted May 31, 2020 Report Share Posted May 31, 2020 I tried contacting the seller of the part you posted, and they don't deliver to Canada or Calgary exactly. Thanks though. Quote Link to comment
Draker Posted May 31, 2020 Report Share Posted May 31, 2020 13 hours ago, Snowball said: I tried contacting the seller of the part you posted, and they don't deliver to Canada or Calgary exactly. Thanks though. front or rear? Quote Link to comment
Draker Posted June 1, 2020 Report Share Posted June 1, 2020 4 hours ago, Snowball said: Rear I have these parts. $30 plus shipping from Oregon. Pm if interested. Quote Link to comment
banzai510(hainz) Posted June 1, 2020 Author Report Share Posted June 1, 2020 Draker PM Snowball Im pretty much done with my truck all is well beside the rear side marker lights 3 Quote Link to comment
Icehouse Posted June 23, 2020 Report Share Posted June 23, 2020 The finished product. 4 Quote Link to comment
]2eDeYe Posted June 23, 2020 Report Share Posted June 23, 2020 How did I miss this? Hainz why you smashing up my truck? Nice work fixing that up guys. 🙂 1 Quote Link to comment
banzai510(hainz) Posted June 23, 2020 Author Report Share Posted June 23, 2020 its back on the road. Been driving the Rising Sun Car last 2 days. Go back to 521 2mrw. Lots of waves ,thumbs up ect…. cool car also driving that 92 Toyota that now has 78k miles on it.(nobody waves at me or even looks) 2 Quote Link to comment
gene knight Posted June 29, 2020 Report Share Posted June 29, 2020 glad you are ok banzai510(hainz) i might have some extra side makers for 521 1 Quote Link to comment
banzai510(hainz) Posted June 30, 2020 Author Report Share Posted June 30, 2020 I go them already from Daniel 1 Quote Link to comment
vicdat Posted June 30, 2020 Report Share Posted June 30, 2020 On 5/15/2020 at 1:23 PM, banzai510(hainz) said: well lucky I always ck for end play when I have the wheels up on the kingpins Yeah ....this was 40 years ago....I wasn't so smart back then.... Vicdat Quote Link to comment
