Idaho Hillbilly Posted May 7, 2020 Report Share Posted May 7, 2020 Hey guys, I already have this information out there in two separate threads now (my build thread and the brake forum), but figured I'd put it here too due to relevance and to give it it's own thread. I've never seen the info on Ratsun and had to work through it myself, so forgive me if this is already known to some of you. The common upgrade for the 70-78 240/280z car guys is to install brake calipers/pads from a 79-84 Toyota 4x4. These are 4 piston calipers with larger pads. Well, it turns out that the 240/280z calipers will bolt in to any 620 with factory disc fronts... That alone is an improvement and offers an alternative to our hard to find calipers. Last night i purchased one of the Toyota calipers and some pads to give them a test fit on my SVO-620 build and the pics speak for themselves... A look at the mounting area/backing plate stock The small trim that was needed to make the 4 piston calipers fit Caliper fitment after installation Clearance with a 15" wheel bolted up Anyways, I hope the info proves valuable to some of you out there. 2 Quote Link to comment
datzenmike Posted May 7, 2020 Report Share Posted May 7, 2020 I did a Toyota SAS on my 620 and with transfer case, four heavy leaf springs, Z24 engine, power steering and a bunch of other things it weighed about 3,500-3,600 at the weigh scales with me in it. I bought kits and rebuilt these 4 piston calipers and once I got the bias right on the rears it would really stop!!! Good news is I was able to keep and use the stock '78-'79 brake master cylinder. It should be noted here again that these are the pre '85? calipers that fit the non vented rotor. 1 Quote Link to comment
Stoffregen Motorsports Posted May 7, 2020 Report Share Posted May 7, 2020 I've got a Datsun master cylinder on my '57 Rover and it powers the Toyota vented rotor calipers just fine. No power booster either. 1 Quote Link to comment
datzenmike Posted May 7, 2020 Report Share Posted May 7, 2020 I have a set of the vented somewhere. They look identical to the non just wider. Quote Link to comment
Stoffregen Motorsports Posted May 10, 2020 Report Share Posted May 10, 2020 (edited) On 5/7/2020 at 10:03 AM, datzenmike said: I have a set of the vented somewhere. They look identical to the non just wider. There are two different vented rotor calipers. The 4cylinder IFS caliper has four pistons in two different sizes (two small and two large). The V6 caliper has four large pistons and is identified by cooling fins cast into the caliper body. The calipers pictured above are 4cyl calipers and obviously non-vented. The vented rotor calipers can also be found on FJ60/62 Land Cruisers. Edited May 10, 2020 by Stoffregen Motorsports Quote Link to comment
datzenmike Posted May 10, 2020 Report Share Posted May 10, 2020 These were on a '86? 4 cylinder I guess. Has large and small pistons. 1 Quote Link to comment
unitrak750 Posted December 31, 2023 Report Share Posted December 31, 2023 This is a great post. I just verified on my 82 720 4x4 the 79-85 Toyota caliper bolts right up with minor trimming of the backing plate. I'm running the stock steel 15 rims and plenty of room. Quote Link to comment
