gene knight Posted May 6, 2020 Report Share Posted May 6, 2020 (edited) does the nose cone on a 4 speed need a gasket? if so how do i remove the nose cone? i took out the bolts and tried to remove it but it is hanging up on something. is there a trick to removing it? i made sure it was in neutral Edited May 6, 2020 by gene knight Quote Link to comment
datzenmike Posted May 6, 2020 Report Share Posted May 6, 2020 This style transmission with the removable bottom pan? If the pivot ball for the clutch arm is on it, reach in through the dust cover with a socket extension and knock it loose... Do NOT hammer on the nose the input spline is in. Quote Link to comment
gene knight Posted May 7, 2020 Author Report Share Posted May 7, 2020 datzenmike: i am talking about the nose cone where the speedo cable goes and where the shifter is at. where do i get a breather valve that is shown on your picture Quote Link to comment
