69' Datsun Roadster 2000
Wingzero
What up Ratsun!
Picked up this Roadster with no engine. Plans are to build a L20B to a 2.3 Liter Stroker and hook that up to a 5 speed L series transmission. I have names this project Datsun Roadster 2300. I also picked up another Roadster and plan to swap the flat dash onto the 69 Roadster. More to come!
Edited by Wingzero
Deleted bad photo
  • Replies 9
Please do not use Photobucket, most cannot see your photos.
When I clicked on them links I could see tiny photos of a Toyota, 2 of a white roadster and 3 of a dark rusty colored looking roadster, the photos are very small, I use Postimage and a lot of others do also without issues.
On 5/7/2020 at 3:41 PM, Fetch said:
Wing, If you have not already, check out an L16 install and a KA24 first a 311's.org .
The popular swap is the sr20 twin cam engine. Kits and wiring are available as well as brake upgrades. There is a complete install guide on 311's.org. Check it out first.
http://www.311s.org/pmwiki-311/pmwiki.php?n=TechSection.EngineSwaps
Thanks for the reference material Fetch! I definitely have used 311s forum as my main source for info and advice. I'm sticking with the L23 stroker since I already had an L20B engine that was donated to me. This is essentially the same engine that is in Daniel Wu's "Tanto" Datsun 510.
L20B - Stock and stripped
L20B crankshaft (86mm stroke) vs Z24 crankshaft (96mm stroke)
Mahle Forged Pistons: 88mm Bore
On 5/10/2020 at 12:20 PM, edwardthrottle said:
@WIngzero - nice!  Im new myself to the ratsun community and im looking to get a roadster..  Im pretty excited to see what you have going on.  BTW...  what are you going to with the other roadster once you have transplanted the dash
Hi Edward,
I plan on building my stroker engine first and after that I'll get working on the transmission. I probably will be swapping the dash 1-2 years from now as interior and frame is the final stage of my project.
Here's some progress I have completed for the L23 Stroker build. All of my aluminum parts have been vapor blasted at a local shop.
Timing Cover
Valve Cover
  • 9 months later...
