wayno Posted April 26, 2020 Report Share Posted April 26, 2020 Maybe a GL18 engine out of a 1972 Skyline??? Someone imported one a while back in the Bay area and I think they were going to do a conversion, maybe that is this engine. Quote Link to comment
pdp8 Posted April 27, 2020 Author Report Share Posted April 27, 2020 This is in the bay area and the guy was going to do a swap, but he gave up and is going with a 2.xL something, so is selling the motor. Are they magic in some way or just cool because they are fairly obscure? Quote Link to comment
wayno Posted April 27, 2020 Report Share Posted April 27, 2020 I really don't know a lot about them, there is a thread about that vehicle on Ratsun, it had an 1800 in it but I cannot find the thread. It has a cross flow head, that might be a good thing, it depends on how well the head was designed, I believe this engine ran and may have been driven before being removed, or I may be thinking of an entirely different car/engine. Quote Link to comment
datzenmike Posted April 27, 2020 Report Share Posted April 27, 2020 Cross flow keeps the hot exhaust ports away from the intake ports, intake and carb(s). Less heat is dumped into the cooling system because there is less need to cool around the hot intake ports. Additionally if a turbo is used, the compressed air can go across the front of the engine through an inter cooler to the intake side. You can also run the intake and exhaust valves at different angles and the combustion chamber closer to, or hemispheric. Quote Link to comment
Crashtd420 Posted April 27, 2020 Report Share Posted April 27, 2020 22 hours ago, wayno said: Maybe a GL18 engine out of a 1972 Skyline??? Someone imported one a while back in the Bay area and I think they were going to do a conversion, maybe that is this engine. You were close wayno.... 1 too many letters.... gl1800 is a honda gold wing engine.... The nissan G18 was the motor your thinking about.... its a Prince G engine... https://en.wikipedia.org/wiki/Prince_G_engine And It looks like they put the firing order right on the valve cover... 1 Quote Link to comment
wayno Posted April 28, 2020 Report Share Posted April 28, 2020 Maybe it was what the car was called, 1972 Nissan Skyline GL 1800, I do know it was a short nose version. https://www.hemmings.com/stories/2015/09/09/hemmings-find-of-the-day-1972-nissan-skyline-gl-1800 Some where on here(Ratsun) is a thread of the car that this engine likely came out of, but I cannot find the thread. Quote Link to comment
Crashtd420 Posted April 28, 2020 Report Share Posted April 28, 2020 4 hours ago, wayno said: Maybe it was what the car was called, 1972 Nissan Skyline GL 1800, I do know it was a short nose version. https://www.hemmings.com/stories/2015/09/09/hemmings-find-of-the-day-1972-nissan-skyline-gl-1800 Some where on here(Ratsun) is a thread of the car that this engine likely came out of, but I cannot find the thread. That would make sense.... Quote Link to comment
Eric Posted May 2, 2020 Report Share Posted May 2, 2020 Thats is a 1800 motor which was in the Shortnose C10, The C30 Laurel and the later C130 Laurel. Called G18 or G20. There even was a G15, 1500cc available in the cheapest C10 Skyline. Quote Link to comment
Stoffregen Motorsports Posted May 2, 2020 Report Share Posted May 2, 2020 I don't know anything about this motor, and info is scarce, but the G motor looks like maybe an L bottom end with a crossflow head? I wonder if any parts interchange. Quote Link to comment
datzenmike Posted May 2, 2020 Report Share Posted May 2, 2020 80 X 74 B&S for the G all L13, L14 and L16 bores were 83. Only the L16 was close to the same stroke at 73.7 Quote Link to comment
Stoffregen Motorsports Posted May 3, 2020 Report Share Posted May 3, 2020 Does anyone have better pics of this engine? I found only a couple online and neither had a good pic of the block or front cover. Quote Link to comment
ZeroSports Posted May 18, 2020 Report Share Posted May 18, 2020 This is G18 engine. Single carburetor. On photo G20 engine with double carburetor. Quote Link to comment
