PapaJohnsCollege Posted April 24, 2020 Report Share Posted April 24, 2020 I'm taking the steering column cover off of my truck and the last step is to remove the ignition switch but I don't see any other screws how does this thing come off. Quote Link to comment
datzenmike Posted April 24, 2020 Report Share Posted April 24, 2020 The screws installed by the factory have a necked down area under the head and when over tightened the head shears off making them more difficult for thieves to remove. What I did was just hacksaw across them... With a new slot any flat bladed screw driver will remove them... and the clamp comes apart. Yours may vary but the idea is the same I think you can buy these break away fasteners, but why bother? Quote Link to comment
PapaJohnsCollege Posted April 24, 2020 Author Report Share Posted April 24, 2020 Maybe im using the wrong part name, I mean the part you put the key into, and taking it out of the plastic housing Quote Link to comment
Jersey Posted April 24, 2020 Report Share Posted April 24, 2020 If you’re talking about the round plastic nut that holds the ignition in the housing, there will be two little holes on the face of the nut. The right tool would be a spanner wrench. However, if you’re careful, you can use small needle nose pliers. Unplug the ignition and hold it from behind and insert needle nose into the holes and carefully turn counter clockwise to loosen the nut. Installation is the reverse order. Quote Link to comment
datzenmike Posted April 24, 2020 Report Share Posted April 24, 2020 This part above. The key goes in where my bottom finger is. The key cylinder is about where those red and blue wires are and the ignition switch is at the very top with all the wires sticking out and you can see the small screw to hold it in place. The locking mechanism is in between these tow parts. The ignition key cylinder is inside a casting, not plastic or it would be too easy the break into and steal. Quote Link to comment
PapaJohnsCollege Posted April 24, 2020 Author Report Share Posted April 24, 2020 The part your holding is a very different part than what I'm trying to take out and to Jersey I'm talking about removing the whole unit from the steering column cover, it would be easier to show with a picture but I'm not sure how to add one Quote Link to comment
Jersey Posted April 24, 2020 Report Share Posted April 24, 2020 “The whole unit” being the ignition switch...using the method I posted above, will remove the ignition switch. The 620 switch is only held in by the round spanner nut. And if I remember, correctly...to remove the housing you don’t need to remove the switch. Just remove all of the screws to remove the top cover, then there is a very small phillips head machine screw on the bottom cover on the ignition side of the column. Remove that first, and then remove the two screws attaching the bottom cover to the column. You can then remove it and of course, you’ve all ready unplugged the ignition. Now, if what we’re saying isn’t helpful to you, please post some pictures. Good luck. Quote Link to comment
PapaJohnsCollege Posted April 24, 2020 Author Report Share Posted April 24, 2020 Yes that worked thank you, I thought you might have meant the metal key part from the casing around it earlier Quote Link to comment
datzenmike Posted April 24, 2020 Report Share Posted April 24, 2020 I must be thinking of something else. Carry on. Quote Link to comment
PapaJohnsCollege Posted April 25, 2020 Author Report Share Posted April 25, 2020 Ya your talking about a 280z or something with a steering lock I believe Quote Link to comment
datzenmike Posted April 25, 2020 Report Share Posted April 25, 2020 Yeah I remember now the '78 620 I had, had a hole in the column but no lock thing on the key cylinder. Quote Link to comment
